Post your LIFTED pix here!
Thats all all I have as far as the front Profile of the Wheel and Tires go. 4 1/2 inch Back Space. 4 Wheel Parts in Lynnwood WA, Mike the Manager helped establish the Back Spacing properly. I like how it turned out for sure. Here's a rear profile as well. It's interesting when you talk to les Schwab and the other tire stores the talk about offset vs. Back Spacing and the 4x4 Shops talk about Back Space which is American and makes way more sense to me. I had 5 different opinions form different tire stores and I am glad I went where I did. I needed to trim a little on the front, no big deal.
Just Getting Started, Custom 2 Tone Leather Black/Graphite, Nav. ARB 3" Lift, 9x17 Fuel Boost Wheels, BFG KM2's 285 70 17's, T-Rex, Gobi Stealth Roof Rack & Ladder w/4-6" Rigid LED Flood/Driving Lights and 2 Pia Back up Lights on the way. Having a good time setting it up for Hunting Season. Any other Ideas out there, would like to here what your thoughts are.:50cal::sniper:
Would you mind sharing the details regarding your leather interior? Pics? Etc... I sent you a PM regarding it as well...
2/1 :Lift
Blue thunder , where did you purchase the 2/1 lift from ??
Does the 2" front have a preload and topout spacer or just one or the other ?
I got the lift from Superior Off-Road in Gresham Or. Houston is the guy that does most of the suspension stuff... It was just spacers front & back.
Here are some Pics of the Interior and I threw in a front Shot. The photos are way lighter than in reality for some reason, They are Black on the sides and Graphite in the middle up through the head rest.
2011 BP LE -- Truxxx 3"/1.25" Lift -- BFG A/T 285/55/20
2011 BP LE -- Truxxx 3"/1.25" Lift -- BFG T/A 285/55/20
RZA_3367.jpg~original
RZA_3372.jpg~original
She's dirty and needs a bath but I'm very happy with the results. This truck fits all my needs. I hope Toyota keep pumping the technology into the 4R.
I like all of your rides. Glad I could share mine.
Would you post pics from the front and rear? I want to see how wide the tires look from front/rear since the 4Runner rims are so narrow. Tks
You won most expensive tires on a 5th gen that i've seen so far @ $393 per/tire, those things are about the same as on my 335i Michelin PS2's RFT @ $425 each.
Got'r done....
Almost exactly 1 year from the day I bought the truck....Overland Warehouse 2.5" coil-overs, Light Racing UCAs, OW 2.5" rear shocks, combined with Icon 2" lift rear coils and Icon rear shock shin guards. I have about 1.5" of rake, which I like, and the truck rides awesome. I get about 1/8" of compression when I load all my work gear in the back, which would normally compress the stock coils about 1/2". Every place I go people come up to me and comment on my truck...(even though it needs a wash!)
Looks fabulous! I'm also happy to hear you really like the ride quality since I am in the process of installing almost the exact same suspension (I've opted for the SAW 1.5" rear coils).
At what height are your front OW coilovers set? I'm also eyeballing the Icon shin guards for the rear shocks .. any fitting problems with OW rear shocks?
No fit problems at all with the shin guards. I wanted to get the lower shock boots to protect them in the rear but Andries from OW told me that they are not recommended for areas with quite a bit of salt as it will cause more corrosion under the boots (Upstate NY has about 5 months of heavy salting).
I was gonna go with the SAWs as well but they were on back order for quite some time. The Icons are not too high IMO. The fronts are easy to adjust out by using the coil-over wrench, but you have to play around with them (adjust/drive to settle/measure and adjust again) to get everything where you want it and level the "Toyota lean." Basically one side is higher than the other to reduce the front lean, but the rear is still a little under a 1/2 inch off. So standing behind the truck you can still notice a little lean.
The ride is fantastic, just like I would expect it to be for a trail rated vehicle. Its very firm but not bone jarring. The front-end brake dive is gone with just a little dive under hard breaking. Larger bumps/ruts or anything taken on-road at normal speeds are smooth. Although its only a 2 inch lift in the rear and prob around 3ish in the front, it is very noticeable and looks great.
Nice looking truck 1traildriver!
Thanks for you post, you set my mind at ease. I have BFG AT 275 70 17 with 17x8 crawl wheels and my lift is going on tomorrow morning.
I initially got this tire size when I wasn't going to lift. That changed almost immediately after the tires went on.( still wasn't 100% happy with the look, and have rubbing in front when turning) I was upset thinking they would look too small after the lift and regreted not going 285.
275 look perfect on your truck, I hope mine looks just as good.
Thanks for sharing this, 1traildriver .. much appreciated!
Seattle036.jpg~original
Teaser...Got the truck back late tonight and my camera sucks in low-light conditions...I'll have better pics of the truck when I test out the new setup in George Washington National Forest.
Updated pics of my 2010 Trail OME 884 W/topout spacer Toytec superflex 285/70/17 BFG KM2's
REE
