Post your LIFTED pix here!
Just fits in the garage until the tent goes on for the summer
Bilstein 6112 up front
Icon 2" springs in back
Toytec boss remote resi shocks
285 tires
My Bilstein 6112s set on the 3rd clip in front for 2" of lift, the rears have Icon 2" lift springs paired with Bilstein 5100 shocks. Like the look, love the ride!
Great looking rig, I am looking into a similar set up.
OK I installed a toytec 2.5 boss kit with the HD rear springs and light racing UCA. I went with the HD Springs cause I pull a casita travel traveler and it helps with the extra weight in the rear. Now the front... from hub to fender is 23inches on both sides however the driver shock had to be cranked down more than the passenger. So say from top of shock to lock ring is 2.5inches space and the passenger is .75 inches. Is this normal? Toytec says that a lot of the new toys have a have that issue. Am I being told truth or BS. The truck has had two alignments and it looks good on paper. Rides well looks good just wonder about the difference in tension on shocks and if anyone else has had this.
Have you heard of people having problems with stock parts failing after moving to 2.5" in the front and 1.5" in the rear? For example, CV due to added stress?
Mahaloz, had to make sure i ordered the correct spacer for the rears. Going to replace my 1"cornfeds,bilsteins going up from 1.75 to 2.5
2010 sr5
After about 8 months with my first 4Runner I finally got around to some mods. 3" lift with new Fuel Beast 18's with Nitto Trail Grapplers. In the process of blacking out all the chrome. Next will be N-Fab nerf bars then Gobi Stealth Rack.
2010 SR5 | 3" Daystar | Fuel Beast 18x9 | 285/65/18 Nitto Trail Grappler
Front Ride Height
I struggled to get the ride height the same with my 2015 TE. I've got the Toytec Ultimate 3" lift kit.
There's a difference in the stock spring rates between the left and right sides. From my notes it lists the front right rate at 590 lb/in and the front left at 600 lb/in. That implies that the front left is heavier than the front right. Thus if your new springs are the same rate than you'll have to raise the left side spring perch to level the ride height.
She likes to get dirty.
