Post your LIFTED pix here!
OEM Fox shocks/struts/springs
Burtman 2.5/2" spacer lift
Spidertrax 1.25" wheel spacers
Yokohama 285/75r17 Geolandar G003 MT's
How has this lift worked out for ride and performance ?
Just got the tires installed today! Dobinsons IMS 2.5" front/2.0" rear, with Freedom Offroad UCA's. Falken Wildpeak AT3W in 255/80R17
Looks great and that's the same set-up I'm looking to add to my 2020 TRD OF. Do you have any pictures from the front or back so I can see how the tires look? Concerned about the width.
THanks!
THanks!
I'll get some in the next few days. Overall it looks quite factory from the front and rear!
THanks!
Here is a front and back photo, no spacers installed.
Here’s mine:
Eibach Pro Truck 2.75"/1" Lift
Pro Comp 17x9 -6 offset Vertigo wheels
285/70/17 Wildpeaks
No rub issues
Any fender liner/body chop mods needed with this set up? And did you also get UCA?
Yes, there was a slight cut that they had to do just in front of the front wheels. It was maybe an inch or two cut off the bottom front of the fender. It is almost unnoticeable. I have no rubbing whatsoever. They also installed SPC Adjustable UCAs.
Hey guys I just installed a 1.5”/2” Cornfeed spacer lift on my 2020 Pro with 285/70 Toyo Open Country M/T tires. They rub on the mud flaps when turning. I was not expecting that. Is this normal?
I like the tires! Were the wheel spacers required to prevent rubbing with the UCAs or just for looks? Stock or aftermarket UCAs? How do you like the Geolandar MTs? I’m thinking of going the 255 route for lighter weight.
Thank you! I installed the spacers the day after I bought the truck and did tires weeks later; I just like the looks with the spacers. I have stock UCA’s. I love the tires and would buy them again.
Lots of things cause tire rub. Wheels, poor alignment, not all tires are created equally. Remove the mud flaps, simple solution.
Doesn't seem too out of the ordinary, those tires run big.
