Power steering pulley
jreask
Member
I just replaced the water pump and timing belt last week. I now have a chirping PS belt. All of the searches I have done lead me to believe that the chirping belt is usually caused by an alignment problem. When I spray water on the PS belt, the chirp goes away for a minute or so and then returns. After examining the pulley on the PS pump, I can move the pulley in and out maybe about 1-2 MM. I am wondering if the nut on the pulley can be tightened or if the shaft itself might have a snap ring that holds it in place inside the housing?
Thanks in advance.
1999 4Runner SR5 with 3.4L V6. 142 K.
Does it chirp all the time, just at start up or when turning? Did you try tightening it? I would think spraying water on a chirping belt would make it squeal like a pig!
Deno91
