Preppers and Bugout Guys...solid tire options
MidnightOffRoad
Has anyone explored any solid tire options for their offroading applications?
I can't find anything that resembles a "kit" and everything I've seen is either a self healing liner/coating or a full on take your tires and drop them off at a certified installer who solid fills them.
Obviously the industrial sector uses solid tire filling but the drawbacks in a daily driver are additional weight and ride harshness.
In a bugout or even a recovery scenario far from civilization, I'm wondering if there's anything available that can be stowed/carried and only used when necessary.
Open cell (like "Great Stuff") is fairly cheap, but I suspect wouldn't have the strength or bearing capacity required to keep a tire from behaving like a flat (maybe, to be determined and tested I suppose).
Closed cell foam is much more expensive and usually requires a binary setup where mixing through a sprayer is required.
There's "sealants" and liners on the market like "slime" and probably some other more sophisticated stuff, but I'm not sure how that actually performs in very harsh conditions. I feel like it's more of a bandaid to get you temporarily back to aid/help.
Any ideas or kits that people are aware of that a person could keep in their vehicle and use under extreme circumstances (we're talking about situations where extended harsh use would be required and saving the tires for "normal" use would be out the window. Situations where you might not be able to get a suitable replacement tire anytime soon).
I'm not a hardcore offroader. My rig is primarily a daily driver that will double duty as a bugout vehicle if required. But I suppose there's some commonalities between harsh offroad-middle of nowhere applications and crazy dystopian prepper scenarios where puncture hazards abound and no guarantee of replacement tires is a reasonable expectation.
Get yourself a patch kit and durable tires w/ a spare. Good for 95% of zombie invasions.
Maybe an onboard air system for lightning fast tire changes with air tools once you temporarily escape the zombies.
The next logical step is to look into a dually rear tire setup.
I presume you have a bugout trailer or some other type of cargo accommodations?
If not, I’d consider a small off road trailer and throw an entire extra set of wheels with mounted E rated tires in there. It’s gonna take up space but it’s your best bet if you’re looking at long term survival without dependence.
good tire patch & plug kit, high volume compressor, and a bead breaker tool
in a real SHTF situation you'll run out of fuel before your tires are an issue
Some other options:
As stated, carry a really good tire repair kit and practice using it.
https://www.extremeoutback.com/product/27/The+Ultimate+Puncture+Repair+Kit+Part#+001-009.html
You can carry unmounted tires (less weight) and learn how to mount and dismount them yourself.
If you get an off road trailer (BOT = Bug Out Trailer) get the same size tires and rims for the trailer. In a worse case scenario you take the trailer tires off for the 4Runner and abandon the trailer.
I have my air compressor mounted under the hood and wired in.
The OP is in South Florida so bugging out to escape a hurricane is a very real possibility .
...and while waiting for the end of the world you can take your "bug-out" rig on camping trips to remote locations.... :bravo:
There is no scenario that fuel lasts longer than 5 days. Power will be lucky to last that long as well. Trash is nearly intolerable after 2 weeks. Food is gone by day 10. Society is in full collapse by Day 21.
so one option is to lift and re-gear your truck so you can run a set of Humvee tires with the magnesium run flat inserts.
Trail Worthy Fab sells sets with recentered rims so you can still maintain your 6x5.5" bolt pattern
The best tires for a bug out scenario are a good pair of boots. Would recommend cardio + weight training exercises daily, 6 days a week. :cowboy:
My favorite thing about the pepper industry is the amount of 300+ lb people spending real money on prepper supplies when getting in shape would be a much better investment
Sent from my SM-G930V using Tapatalk
Perhaps they are storing cellular fuel? Can't beat 9 kcal/g
Southshore
