Pull Audio from which wires?
wsmc831
Hello.
2010 LE with Jbl nav system. I'm putting in a couple modest subs under the front seat and so far haven't found a suitable location to graft an input from. I read Antmans thread and am now thinking that because I have the Nav I have to pull a source from post amp instead of directly from the Head unit. I'm trying to feed a couple small powered subs and the input source for them when running is much too low. I have it wired very much like Antman but the wiring connector has different colors.
I'm afraid I may have to tap directly from some speakers, but hoping there are some I can tap from behind the unit as everything is run.
I've searched quite a while and looked at wiring diagrams with no luck.
Anyone done this and gotten good levels, if so what wire pairs did you use.
Thanks much.
Duh...figured it out. Took a preamp signal from back of deck into some dissected rca cables. My mistake was thinking they were speaker level from back of HU.
If my life were to depend on my vehicle, why would I play with the electrical system if I didn't know what I was doing?
Great troll. Truly impressive.
My upgraded system with 5 channel amp, 2 subs and all new speakers work great, thanks for asking.
You must seriously be lacking control in your everyday life to try and stir the pot on an internet forum so much. I hope you someday find some self respect.
MMJR_T4R
