Question about 4Runner ground clearance.
Churn
Why limited with 20" tires has the same ground clearance as SR5 with 17" tires? If using 17" tires on limited 4Runner, will the ground clearance be lower with 3"? Although I am not sure if it is possible to put 17" tires on limited.
Those are the diameter of the wheels, not the outer diameter of the tires.
If you actually had 20" and 17" tires, your ground clearance difference would only be 1.5"
Yes, you can put 17" wheels on a limited
Thanks for correction. I do think 20" tire is big for 4Runner, 18" tire is perfect, like used on GX460.
Spddmn133
