Question About Heated Mirror Replacement
It just pops off! Just be very careful. The new one will just snap back in. You should be able to do it just by using your hands. I pushed the mirror as far as it could pivot horizontally then I just pulled it off. That worked for me.
Awesome man, thank you! I'm going to order that replacement off amazon.:bounce:
It really is that easy. I just used a little trim pry tool, angled the mirror up all the way so the bottom edge is sticking out, and it just pops off with a little prying. Undo the plug, put the new one on, then gently snap it in place. Takes just a couple minutes. In the last image in your Amazon link, you can see the two tabs on top that slot in, and the two slots that clip on down low.
H.Sikina
