So I went to do my brakes.
Low and behold I'm not in this thread....
You know what happened don't you!?
:mad2:
Just like what happened to me. You noticed your brake pads are covered in gear oil.
Yes I did. There wasn't much in there that wasn't covered in gear oil.
Bummer. [MENTION=102606]infamousRNR[/MENTION] is doing the final touches on 3 videos we're putting out that will show people how to do this repair on ABS and Non-ABS rear ends along with an extra video dedicated to just the press work that shows other ways to accomplish the pressing with some items you can get a local hardware store.
To do the repair all on your own, it does require an investment in tools depending how you tackle it. Our video shows using a Harbor Freight press, a special axle tool sold by Durasolid and a bearing splitter.
If you don't want to invest in any special tools, at the very least pull the axles yourself because it's very easy and find a machine shop that knows what they're doing and have them do the press work for you.
The process of pulling the axle was stupid easy. I was also able to get the seals from Toyota (got two sets, one for each side) as well as the PCV which i've been wanting to replace. All out the door about $80.
This is possibly a mistake on my part, but I opted to not worry about the bearings and do just the seals. Getting them in was a pain until I decided for giggles to use the axle itself to start the inner seal. perfect. Used the mounting bolts to slowly get it started. Then tapped slowly and patiently around the seal to get it all the way down. There's a audible difference when the seal sits all the way against the inside.
So far, so good. Of course it's only been 4 days.
If it happens again I'll have the bearings, or invest in the tools depending on cost, pressed in.
So my truck has 220k miles on it, but rides very smooth down the road. I just picked up an e-Locker and 4Runner housing (because I didn't want to deal with modifying my original housing).... should I do the axle bearings just because?
The obvious thought that I have is that I should because I'm gonna have everything apart, but at the same time, I feel like the expense is pretty high for something that I don't need at the moment.
My other thought (and why I'm asking here for those who have done it) is that getting the axles out looks fairly easy, especially with the tools and equipment I have available. So if I forego doing them now and they go bad in say 10k miles it won't be much more of an effort to get them out and do them then and I'm only out a couple bucks in seals.
Unfortunately I don't have extensive history to see if they have every been done before. Any help would be great.
You're right, getting the axles out is easy. If you had a press and special tools to do all the work yourself, I'd say definitely replace the bearings and seals before putting it back together. But, you could also find a local machine shop that does good work and doesn't charge an arm and a leg and get the press work done that way.
To save money, you can reuse both retainers by swapping the positions. Put the one that was against the bearing in the position where it meets up with the axle seal and then put the one that was originally meeting up with the axle seal against the bearing. The reason for the swap is the seal lip wears a mark into the retainer and it's best not to reuse it in this position. You can also reuse the ABS sensor rotor.
You mention if you slap everything together and get a failure 10k down the road it's no big deal because it's easy to pull the axles. This is true but what if it happens when you are on a road trip and are 1000+ miles from home? Not good. You also mention if you do experience an axle seal failure it will just be a couple bucks in seals. Please read my response above about just replacing the seals. Many that have gone before you have done exactly this and then had the headache of another axle seal failure, contaminated brakes and the hassle to do the job all over again.
It's your truck, your time and your money but your attempt to save money upfront might bite you in the ass later on down the road and maybe at a time that's none too convenient.
Thanks for the response, this is a great point of view. I actually have access to a big shop press, I just don't have the axle removal tool to separate them from the drum. I guess I could just ask in the SoCal forum to see if anyone has one I could borrow, or weld up a janky version of one, just for this job.
You just convinced me to do them all, thanks again!
I just had to do this, only to realize that the ring that sits against the seal was way too far down. So I'm guessing that either the previous owner or his mechanic must have put everything together wrong. Luckily I caught it the day after I'd assembled everything and pulled it apart (again!) and moved the inner ring, looks like it's sealing now. I don't understand why someone wouldn't take proper measurements before pulling it all apart.
Another reason to do your own work when you have the time, tools and know-how. A Toyota dealership screwed up my axle seal job and they put one of their most knowledgeable mechanics on the job. The guy didn't even know what a grease test was.
I am getting ready to install ARB locker and am worried about needing to replace inner and outer axle seals once I take the axle shafts out from the axle housing. I can replace inner but don't have tools and press to do outer.
