rear coil suggestions
marcel
so im sitting at about 38" in the front and was wondering which coil would work best in the back to level it out or give slight rake. OME 906 or 890?
What year is your 4runner? I just inserted 890's from Toytec, They are actually Old Man Emu. Toytec claims 3"lift from them, but you have to remember they are spec. off something like a 96 or 01. When I intalled them I maybe got 1.75" of lift, I drive a 98. Ended up pulling them and putting the 1.5" daystar rubber spacer that I was intially sitting on w/ stock springs. I measure 25in from center hub to fender in the front, and 26in from center hub to fender in the rear. Maybe LC would work better? 7-8 coil?
Pic1.Stock coils w/ 1.5" spacer
Pic2. 890 Old Man Emu w/ 1.5" spacer
Ps. when I installed the 890 w/o the space it basically rode the same height as pic1.
i have 98 and 7 wrap with no spacers should even it out and give a little rake, but remember lc coils are soft so if rake is too much you can just load something in the bacl to even it out, 8 wrap would give 4-5 inches on tha back
i have a 98 as well..
what is your measurement from ground to fender with 7 wraps? were could i get a pair?
I just measured what my my ground to fend height is and it sit at a little under 40in on the front... so if your at 38inches then the Old Man Emu 890's maybe just what you're looking for.... and the 890's are maybe a smiggin harder than my stock 4runner springs. So if you like the way the rear rides now, I would suggest 890's. LC if you can find the same color codes for bothside or it will ride about an 1in high on the driver side.
i h8mud.com is a lc forum they usually have them look into the classified section, good luck with the find, i know how u feel i hate when **** dont go as planned
