Has anyone had a chance to finish their install yet? I've sent a bunch of kits out but haven't heard anything.
On another note, the EBC Yellowstuff pads are way better than the Hawk HPS. Much better initial grab and more confidence inspiring pedal feel.
I'm doing mine (along with another member) on Tuesday 9-15. We'll take lots of pics and update the thread afterwards
Sorry, I thought I'd have this done by now but just can't get a break.
Still need to purchase the rest plus others to get the 4Runner ready for towing.
I don't think bleeding is your problem. I don't have an 01-02, so I could be wrong, but if there was air in the system your pedal would most likely feel soft and/or press to the floor. The other thing that has me thinking it isn't a bleeding problem is that the electronic booster is in the engine bay, right? If you only replaced the rear lines, air shouldn't have made it all the way up to the booster or any of the ABS components that are under the hood. That should rule out needing to have an electronic bleed done for the booster.
I think that the resistance thing may be a possibility though. It might be worth adding a residual valve to the rear brake line to hold more pressure in the lines.
It would be good if there was some specs form Toyota on the psi a stock system should run at. If we had access to that, we could try to recreate it in the modified system. [MENTION=118207]midcoma[/MENTION] I’m seeing a number of possible valves with different psi ratings... do you think a single 2psi in-line where the main line splits into the two rear brakes would work or should I do one before each rear brake? 4psi total?
Great! I look forward to seeing how it goes.
Nothing to apologize for. There's definitely more important things going on in the word at the moment.
This is definitely a mod you want to make sure you have all the parts for before you start. :thumb:
Ok. I’ve come to find out I need to redo the bearings and seals on the differential so time to get this done also.
I have a master tech friend of mine helping out and he asked if anyone has had to put in a new adjustable proportioning valve. Any additional items people have noticed they needed?
The conversion is going into a 1999 5speed
I haven’t done this yet but I plan to put a proportioning valve in, however I’ll be deleting the whole abs system while I’m at it, it’s already disabled
Where are you ordering the valve from. That’s the one part I don’t know where to purchase and which one to go with. Definitely don’t want to get rid of the abs system though
you shouldn't need a proportioning valve with ABS, that's why our runners didn't come with one unless you have the non-rear-ABS axle (or Tacoma). I plan to run a residual valve if the pedal feels squishy.
So where exactly would you put the residual valve. Really have zero knowledge of this at all.
Update for my 01-02 doods! A second brake bleed has my electronic booster running as it did before the swap!...
