Thanks for the inspiration ARK_SWAMP_RIDER, I replaced the stock sub with a Pioneer (TS-SW2002D2), no cutting required, slipped a Cobalt 3002 Amplifier under the passenger and dissected a universal bass control to fit into one of the blank center console buttons. It took all day yesterday to complete as I didn't want to "half-ass" anything, and so all wires and aftermarket equipment are hidden. I'm not sure how it'd sound without sound dampening material, but I didn't chance it as you may see in the following pictures. Sorry for taking only 3 pictures, nothing was left loose...
What is that ugly wire coming out of the console? You say you didnt want to half ass anything but whats that about?
Greetings Ark_Swamp.. I've been doing much research on the 4th Gen Jbl Oem sub replacement as mine is also blown, however after removing all plastics and inspecting, i didn't notice anything visible to the sub at all to cause such a Terrible sound.. oh well.. I am on to adding a new one. I like to simply replace with oem, but looks pricy and poor quality.
I have been following your write up for almost 24hrs now, and I believe I've decided to go the same jl route you did + amp. This if for my gf ride. would you strongly suggest even for just a swap to add in the amp instead of replacing oem with RF/Kicker,etc?
1.When splicing the amp into the rear speaker to simulate "RCA" do you have any pics describing that process?
2.how did you wire your sub from the amp?
Thank you for your help. I am looking for a clean sound that is not from the days of 2 12" in a ported box, but that of a professional studio.ha.cheapest route. I to have wired several cars and am mainly wondering about how to tap the amp into the rear without a line output converter. Thanks again!
Thanks 97BlackAckCL..I can answer a few of these questions for you, I actually have the LOC that you need for sale, it has to use an amped signal. That is where you do the splicing, into the LOC inputs.(Let me know if you're interested in the LOC, it's brand new never used.)
Some people have swapped just the sub for a newer sub and had decent results, however if you're looking for "studio" performance, you definitely are going to want to add the amp. As for wiring the sub from the amp, I bridged my 2 channels on the sub into the monoblock amp.
You can see the 2 sets of twisted wire pairs ready to go into the amp.
Wanting to upgrade my sub/amp. Nothing fancy, going to go with the small one in this thread. One question though, is both the sub and the seekers amplified in the 4runner with JBL system or only the sub?
Hi msa4033,I have an OEM enclosure/sub/amp for a 4th gen available for sale if anyone is interested. PM me if you're interested.
[MENTION=44866]ARK_SWAMP_RIDER[/MENTION]The harness plugs in there and has 5 wires on the other end (or 4, depending on the amp, the fifth is just a ground that isn't used). You go by the owners manual and hook up two positives and two negatives, then plug that harness into the amp and you're good to go. Hope that is clear, if not just let me know and I'll try to explain it better.
[MENTION=87687]LTDSC[/MENTION] , see my question above.Speakers and the amp are ran off the JBL amp. I have the JBL amp powering my speakers and a separate amp powering my sub.
when you hooked up your aftermarket amp, did you just take both + wires from the JBL amp and hook them up to the single line + input to your amp and both - wires from the JBL amp to the single line - input to the amp.
not sure if this will mess up the amp or not and i am wanting to install everything this weekend. thanks.
