Rock Rat's Imperial Jade Mica "Next Adventure" Build
Congrats! My 4runner and my Japanese made Acuras have been the best autos to me so far. I hope your son's TL reaches as many miles as your 4runner....
Did you have new bearings pressed into the spindles up front? Sorry if you said it somewhere and I missed it.
Rig's looking good! Never really thought about doing red lighting in the cargo area but that makes perfect sense for camping. Definitely going to look into a Lumitec led for the rear
Thanks for the mention!
Good choice upgrading the spindles. If they break out on a trail you could easily be out thousands.
With regards to the TL I heard mentioned, I hope it lasts a long time as well. I've got an 08 with 72K on it right now.
It's definitely worth it. I sat on it for a while trying to figure out the best way to install it. Having it switched with the lift gate was the way to go. Aside from the diffused red glow for camping, I think it would also help keep the bugs away. One of my favorite mods.
If you didn't share your experience on the site I wouldn't have even considered this mod. Thanks again for posting.
So far my son is enjoying the TL. It's an 03 Type S and we're hoping to get some good years out of. He's never going to want to go back to a 4cyl again.
Nice work on the spindles!
Thanks! Took me long enough to finally get started on them.
Mike is still celebrating UW's thrashing of Oregon State today; on their way to Pasadena.
...or perhaps Atalanta, thanks to Ohio. Didn't see that coming. We want Bama now! One game at a time...
It was a gorgeous day at Husky stadium on Saturday. I think we're looking at a solid week of rain beginning today.
Amazing I know...I actually just finished up one of my main projects. Spindles with the new Total Chaos gussets are finally all back together. They go back together nicely with new shiny parts and a 20 ton press.
I'm down to my LCA bushings (which I'm hesitating on because of the whiteline bushings I have sitting in my freezer and the problem Alex had with them) and the SC which I'm still undecided on whether to get a larger fuel pump and bigger fuel injectors ($500 plus - ouch) with the 2.2 pulley.
So pretty! Dont forget me on the old spindles/welding etc...I'm in. I'll do that with the LCA bushings next spring.
Are you going with the 7th injector? If so then you dont need larger injectors.
I'm going with the 5th injector so I'm just upgrading to the W 190 pump.
What was the problem with the LCA and whiteline bushings? I installed the whitelines about a year ago and aside from a lot of unbolting don't recall running into any issues.
Spindles look great man!
Thanks! It feels good to get that project finished finally.
Alex installed whitelines and after about four or five months he said they started squeaking on him. I'm more than likely going to install them anyway but I keep going back and forth on them or OEM.
No worries, I've got you covered on the old ones once I replace everything.
I'm running the AEM FI/C instead of the URD 7th injector. That's why I'm considering going to larger fuel injectors and a bigger pump. Can't seem to find the 318 injectors, only the 325's.
I think there's an alternative to the W 190. IIRC someone on here mentioned how loud the W190 is compared to this other pump. I need to do some research. It might be in the SC thread.
I recommend denso Mitsubishi Evo 8-9 fuel pump. Flows like a 190lph with oem denso reliability and is quiet. I got one installed now.
Denso Evo 8-9 fuel pump. You need the plug since it's not plug and play. Got my pump on ebay with plug for $80.
Not sure if these will fit your fuel rails but the 3RZ & 5VZ has the same stock flow rate & fuel pump.
https://www.fiveomotorsport.com/toyota-tacoma-2320979085
Not sure there is much difference between 318 & 325CC's.
Here's a cool flow rate calculator. 318 would probably the min you want.
https://www.fiveomotorsport.com/flow-rate-calculator -
peacefulpiranha
