Satoshi Mod...Modded
whodat
Ok, so I'm seriously considering doing this mod, it's just that I'm really lazy...
I think the Satoshi mod makes the truck look a lot nicer, but I want to make it my own.
So I plan on adding this little 4inch wise guy, Yoda...
yodaplushwithsound4in.jpg~original
to get this (it's photoshopped)...
TOY-YODA.jpg~original
The problem with this "Yoda" is that he doesn't really look like Yoda, and I tried looking for a small Yoda that looks like Yoda, not really coming up with anything...That's part of the reason why I'm putting this mod off...mostly because I'm lazy though.
And yes I know, it spells TOYYODA, but it's better than TO (people will probably pronounce it like the number "2") YODA.
Opinions? Feel free to hate it, I know not everyone, if any, will like it. I like it though :)
Okay I take back my vote for SocalTRAIL for T4ROTM. Whodat is now the automatic winner. Sorry SocalTRAIL but seriously, your truck has nothing on this mod.
No lift now, but it's on my list when something needs to be replaced due to the SW bumper (shocks, suspension, etc). The stuffed animals make it look lifted, they're my spotters.
Sorry to derail your thread...
but how much did that bumper cause your front end to sag? If any?
If possible could you post up or pm me a side angle shot of your rig?
No worries man. After 2 days with the bumper, I measured the sag to be 1/2". I never measured it again, I should have measured the sag before and after I got some Duratracs 285/70/17 D rated. But I didn't :redbrick:
I'll measure it again from the top of the wheel well to the ground and if someone else wants to chime in what their stock measurements are, maybe that'll do for you? Or do you want me to measure it some other way?
I'll also take a side picture of the truck tomorrow, how far back do you want me to stand? You can definitely tell it's not lifted when you see the side view.
However you measured it the first time will work just fine for me. As for the picture, I just want to see the rake. I'm debating a bumper, and have a spacer lift, but I want to get a general idea of how the front end sag would be after a bumper.
Thanks man!!
Not 100% sure how I feel about it haha.
Oh and are you running a lift with the shrockworks bumper?
I do...Nope...not a fan. To each is own of course!
Just can't see sticking a doll on a vehicle (unless it's an old Bug, I suppose...and I were a chick). :biggrin2:
Thanks man!!
Squatting, roughly 10-15 feet away
20120926_133919.jpg~original
Standing, ~ 20 ft away
20120926_133926.jpg~original
Driver side from across the street
20120926_161336.jpg~original
Sister's truck with stock tires
SC20120926-161549.png~original
Measurements on my truck with 285/70/17 D Duratracs
Front passenger/driver side from top of wheel well to ground 35"
Rear passenger/driver side from top of wheel well to ground 37.5"
Measurements on my sister's truck with stock tires
Front 34"
Rear 37.25"
il_570xN.357858349_phvo.jpg~original
I'm sure someone can run this through a 3D printer or a CNC machine :)
Okki
If this happens, I would be in on the group buy!
You would be surprised by how many smiles I get from people. It feels good that I'm able to put a smile on their faces, simply from a doll (2 actually) :)
Okki
I have a vinyle di-cutter and a 32" HD vinyl printer, if there is interest I could print these up in any size or color, as long as Okki doesn't mind me using his art.
For that matter I can print/cut any decal anyone here needs. We have the equipment for making decal kits on our shiftercarts but would be happy to push out work for forum members. No minimum number, though we prefer not to do just 1 it typically wastes a lot of material.
:reddance:
:reddance:
Wish I could take credit for the artwork, but that was just a google search away.. I saw a decal of it in Ouray at the FJ Summit.
There are some better (larger files) to be found as well.
Okki
The Toyoda sticker is available on Amazon: (link).
My suggestion was to 3D model the artwork so it could be printed or machined out of plastic or metal to be used in the Satoshi mod like the satoshi emblem. you could then also paint the letters to be whatever color you want. a sticker is not very usable on the front grille.
Okki
Suggestions?
Well, I ordered everything for the mod, but don't really know where to find the 3M industrial double sided tape? I just checked Walmart, going to check Home Depot, Menards, Lowes, and some local auto shops Tuesday.
I didn't really like the Yoda plush, so I looked a little harder and found this!
funkoyodawisecracks.jpg~original
I'm going to stop by Barne's and Noble Tuesday, but the dimensions look promising, 5x4"
Now, I'm leaning towards cutting off the base and just use Yoda, but "YODA' MAN" is very cool :)
I will probably cut it in the back to make it flush with the new grill, like so
capture_04.png~original
Then depending on how the thing is made, if it's hollow I will probably drill two holes, like so
capture_05.png~original
and then use these toggle bolts with a couple of washers and bolts to keep them in place
togglebolt.jpg~original
If it isn't hollow, then I will drill on the sides and use zip ties
capture_03.png~original
I really want to avoid drilling on the sides and using zip ties, it won't look "clean" and professional :) Any suggestions?
Got the grill ready to go, will probably try to install it tomorrow or this weekend.
Since I never saw a picture of the back of the TOYOTA emblem, I took one for those who were wondering what it looks like back there
20121005_125439.jpg~original
20121005_161039.jpg~original
20121005_161059.jpg~original
I chopped off the stubs on the back and I used the 3M outdoor mounting tape and trimmed it to match the emblem on the back (thanks for the idea Andrew (Adio3x))
20121010_230923.jpg~original
Then I got this guy and sliced him from the base
20121008_235246.jpg~original
And then made an opening on the bottom, he was hollow inside, thankfully because that made this mod a lot easier!
20121008_235449.jpg~original
I ended up just using two #10 bolts, with some washers and lock nuts, I had to keep a little space between Yoda and the grill so his head would still bobble. Here's the link to his head bobbling :)
Yoda - YouTube
20121010_230657.jpg~original
20121010_230426.jpg~original
20121010_230351.jpg~original
20121010_230305.jpg~original
20121010_225845.jpg~original
20121010_225801.jpg~original
