Installed the spacers today. Cleaned the hubs really well with a small wire brush, some brake cleaner, and a rag. Then used blue colored loctite on the OEM studs and bolted the spacers on. I used blue just because I had it. I called spidertrax and the guy said either blue or red works. I used the provided black acorn lugs on the rears and used the provided ET lugs on the fronts, as instructed. This is because the front studs on the vehicle are a little shorter. The ET lugs will help with thread engagement.
I don't own a torque wrench that's accurate enough but I worked in a tire shop all through college and I have a rough idea of what 83 ft lbs feels like (OEM torque for our 4runners).
I did probably about 90 ft lbs all around tightening the correct order
Then bolted on the OEM wheels. My only concern is that the studs that the wheels now bolt on to (that are pressed in to the spacers) seem like they end up sticking out of the wheel holes longer than the stock studs did. When I tightened down the OEM lugs I felt like maybe the closed end of the lug was going to bottom out before actually getting tight against the wheel. Anyone else have this problem?
Eventually the OEM lugs got tight but it felt like forever tightening them. I drove around and rechecked and they were all still torqued to where I had them around 85-90 or so.
I started rubbing pretty bad on the front wheel liner when turning after installing these too. I do have 265/65r18 Terra Grapplers which are a bit more aggressive. I moved the liner forward and now rub just a tiny bit on the inside corner of the bumper. Will be trimming a little off with my dremel tomorrow.
Moving the liner forward was easy. Just lay underneath and remove the little hex screws. I trimmed a bit off the liner towards the front of the car so I could push the liner forward and use the same clips and hex screws just an inch or so back. I just punctured new holes with a screwdriver.
Gonna follow this guy's post on trimming the bumper.
http://www.toyota-4runner.org/343061-post26.html
On to the pics of mine!
