Scan Gauge II Codes..New stuff
I've also got a 20 minute drive tomorrow so I'll see how it works, then maybe start plunting in some of the other codes.
shayne
So after 10 minutes of warm up time this morning the gauge showed around 10 and after 10 minutes of driving in the city it had worked it's way up to 12, so I thought I'm on the right track but as the highway run started it worked it's way back down to 9 ish.
Tonight I'll try some of the codes on the scangauge web site and see what happens, also it is v e r y slow to react even being a narrow band(?).
shayne
Started the truck this morning and gauge read 5.65. Let it warm up and after 30 miles on the freeway I got to 10.2. Then another 10 miles and I was at 11.7 pretty steady. Even with excelleration on small hills out heald steady unless I really got on it. Then I was getting anywhere from 12.0 - 14.1
So here's my results,
entered in all the scan gauge codes for the air to fuel as per the website(tried all 17), and they all worked. But idling in my driveway, engine all warm and toasty
all my readings were 9.3 - 9.4. If this is true no wonder I'm only getting 200 miles per tank. Driving on the highway its low too, like in the 9's and 10's. Way way too rich, should be around the 14.7.
I've got no engine codes, maf is clean. Only thing I can think of is the O2 sensor, truck has just shy of 23,000 miles so I wouldn't think that's it but maybe.
Somewhere I've got a old lm1 wideband so maybe I'll hook it up and see whats up before I drop a couple hundred on a sensor.
shayne
What coolant temperatures is everyone with a scangauge reading and at what outdoor temp?
I'm as high as 202 yesterday in 80 degree weather in st Louis. What is too high?
good question! I'd like to know this for the tranny temp too. My coolent stays around 199- 2**? the temps have been a mix of 30 degrees one day and 80 degrees.
Here's a dedicated thread on engine temp.
On my scangauge II I've been getting in the range of 180-205 degrees F on my engine coolant reading.
Tranny temp I can average around 170F on normal conditions. Climbing up steep hills the highest I've hit on the tranny was 242F with heavy camping gear and bikes. I've got a TRD tranny cooler on the way that I'll be installing that should help keep things cool. :naughty:
All of this with an outside temp ranging between 60-75F. We are a bit spoiled with the mediterranean weather here in the most western part of California :)
Let me say, I love my Scangauge!!! I do wish it had sound alert warnings and distance to empty (DTE) like I have on my ultragauge EM. Unfortunately my ultragauge can't read tranny, so I may just sell it to someone with an older T4R model that can't report tranny temps.
Hey I just bought a new O2 sensor and Scangauge ll, but have yet to install either; is there anything I can do to help this thread?
Anyone know if we can get oil pressure on SGII? (Does the 2000 T4R w. 3.4L have a pressure transducer already installed)
Or do I need to buy a sensor and install it? (install my own pressure transducer since our trucks don't have one)
What about temp? Guessing we don't have that either?
EDIT: Nevermind... found the info. No oil pressure.
Anyone ever have a need for it? Or does it just not matter much with this engine?
You shouldn't need to worry about oil pressure with the 5VZ-FE. Either you have it....or you don't. And if you don't, the warning light will come on.
shayne
Using your SGII, see if you are in Open Loop or Closed Loop. It's a preset gauge. It'll just say "LP" as you are cycling through them. In closed loop, you should always see 14.5-14.8. If you are seeing AFR's in the 9's and 10's in closed loop, you have a major problem. Heck, if you're seeing 9's and 10's even in open loop, you have a problem. At WOT in open loop, you should still only be running about 11.5...plenty rich.
These are the codes I have programmed:
Horsepower... (kinda lame, and not at all accurate, but interesting to watch a couple times)
TXD: 00
RXF: 400080000000
RXD: 0000
MTH: 000A00170000
Notes: Gasoline Gross/Brake
Short Term Fuel Trim Bank 1
TXD: 686AF10106
RXF: 044105060000
RXD: 2808
MTH: 00C80100FF9C
Notes: +/- 0 to 99
Long Term Fuel Trim Bank 1
TXD: 686AF10107
RXF: 044105070000
RXD: 2808
MTH: 00C80100FF9C
Notes: +/- 0 to 99
Transmission Temperature
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
Notes: n/a, displays in degrees F
Air : Fuel Ratio
TXD: 686AF10124
RXF: 04410524
RXD: 2808
MTH: 05B900800000
Notes: Ratio
Can confirm these codes working on my '01 SR5 4wd automatic. Thanks!
I'm Ron Burgundy?
I deserve this why? Was only trying to help as I had a unique situation in which I hadn't installed my SC ll yet but was willing to contribute to this thread. Don't want to deprive you of your only source of joy but c'mon man life is short.
Exactly, so getting mad over a funny and harmless comment on the Internet is dumb....
Anyone using the fuel level gauge? How accurate is it? Gonna try it at lunch.
GAUGE: Fuel Level
TXD: 686AF1012F
RXF: 0441052F0000
RXD: 2808
MTH: 006400FF0000
NOTES: Percent
044runner4
