I got mine installed last night. First impression, typical Chinese crap. Looks great but zero instructions and crap fit. After tinkering and modifying the top retention clips a bit, I was able to get a decent fit. All of the factory clips and harnesses fit perfectly although a couple of the harnesses that came with the HU don't fit into the head unit because of the retention clips. Took some playing to get those to fit. I just shoved the TV antenna and GPS on top of the HU, didn't bother sticking them anywhere. I ran the sim chip dongle and usb extension into the glove box using the access panel on the back.
The stock HU does have a fan on the side and this one is passively cooled. It gets quite warm to the touch under normal operation so hopefully it doesn't overheat and die. I've played with it a bit and if it stands up to the Las Vegas heat, I think it will be a great replacement for the absolutely awful stock HU.
I've used android auto, spotify and really any other apps that I've thrown at it. Netflix does not work because netflix doesn't work on android devices that aren't google certified (whatever that means). You should be able to
sideload the app but I haven't tried.
I tried to use automate to turn on tether on my phone when it connects to the HU with bluetooth but I didn't like the way that turned out so I got a sim chip and popped it in. Didn't work right away, I had to press the reset button on the front of the HU. That reset button functions as a restart button. A restart brought the sim chip online and I was disappointed with the signal (2 bars when I had 4 on my cell phone). I enabled roaming and it immediately matched what I had on my phone.
All in all, pretty happy. I was really worried about the glare which looks horrible in pics but hasn't been a problem when plugged in.
The HU doesn't turn off completely each time you turn the runner off. The tablet goes to sleep and picks up where you left off. The only way to restart and see the boot screen is to press the reset button on the front.
I've made a couple calls and the mic quality seems decent. As good as the stock mic which I've never really been a fan of. I do have a roof rack so I do get more wind noise than most.
I played with a bluetooth OBD2 sensor and torque app, pretty cool. I bought the wifi version which was dumb, I should have gotten the BT version so I'm just borrowing a friend's for now.
If you like to tinker and you don't like the other T4R head unit options, go for it. If you want something that is absolutely perfect out of the box, wait for a "real" company to offer something. Happy to answer any questions if you are thinking about getting one.
Questions:
Anyone know what app to use to get the TV antenna to work? I didn't see any tv tuner apps on the play store.
How can I replace the icons on the bottom of the main screen with my own? I didn't see a way to do that.
