So it looks like the CTHome T9 head unit is out, waiting for reviews.
Ugh, I decided to pull the trigger on this unit. I just don't like my other options at the moment and don't see anyone else coming out with a better form factor. I hate myself for doing it but since it's done I need some info. Could you share some screenshots of the "About Device" in the settings. Looking for cpu specs, build version, kernel version, etc.
I also plan on using the metra sharkfin adapter to hook up existing antenna to the unit. This also requires a SMA to SMB coupler so I'll see how this works out.
Also, it looks like they include an external mic. Is this the case? Does it look like the facia can be separated from the screen easily for painting?
No external mic included. There is a mic on the front bottom left of the unit. It has a 3.5mm female connection on the harness of the T9 to add an external mic. I used this one https://www.amazon.com/gp/product/B015KY5J7Y/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
No idea if you could take the surround off the radio. It comes as a single unit so I doubt it. I have seen where others have painted the surround after masking off the screen.
Here are pics of the about page of the settings:
Will this be plug and play for a 2012? Their site says 2014+ so I just wanted to double check. For the cost and appearance alone, it might be tough to pass up.
Don't know what the mic plug looks like for the existing mic. Could there be an adapter to connect the existing mic to the T9?
Just looked into this again because I remember it wasn't worth doing but couldn't recall why. Found a few posts about it being amplified by the factory headunit and not worth using compared to an aftermarket mic. I did see one post about OEM mic being better quality but I can't recall if that in a Tacoma or 4runner. Im just going to use an aftermarket mic and put it in the OEM location when I feel like messing with it.
Anyone with an Android phone try this with Android Auto? I've seen lots of Carplay posts, but so far nothing on Android.
I sent a message to both rhino and cartrimhome about the 10-13 harness
rhino, with the labor day discount, is about $430. cartrimhome also has a 15% discount right now puts it at about $490 or so i believe
Both confirmed they do not have a harness for the 10-13's. CarTrimHome said "Sorry, my friend, There is no suitable harness for the time being" and Rhino said "Hello, for TS9, the harness is made for 4Runner specifically. You don't need to make on your self."
So far, CarTrimHome customer service is winning. I asked if they have plans to release one, if they do not I'm going to ask if they want to send me a discounted unit in exchange for helping them create one. We will see...
If not, I may end up buying a head unit when they have a good sale, maybe Black Friday, and go from there in regards to a harness. I'm pretty disappointed they just have a giant mangled mess for an adapter harness when the head unit is specific to one vehicle and they could have done much better.
Good to hear, thanks for the update! I will be following this since I have a 10-13 also.
When I bought my T8 through CarTrimHome they had me send pics of the wiring harness from my 2011 and the plugs they sent. They told me at the time that they were developing a harness and would have it out to me shortly. I got impatient and eventually shipped the unit to another customer instead for reimbursement. It's not very promising that they still do not have one at this point.
I couldn't get it to work by default.
Once I downloaded a particular app, it works fantastic.
It comes preloaded with an app for carplay as well
Sent from my SM-N975U1 using Tapatalk
Which app did you have to download? Did you have to download onto the head unit or your phone? Is it wireless like Carplay?
Update:
Rhino Radio said "Yes we do have a unit to fit your vehicle, the correct harness will come with the unit for proper function."
I asked them to clarify that this harness works on the 10-13 because they are completely different than the 14+, still have heard no response.
CarTrimHome said "Yes, but progress is slow" on the 10-13 harness development, I asked if they needed additional help on it as I'd be glad to assist if they want to send me a radio at a discount. Have not heard back from that yet either.
It's called head unit reloaded. It does have wireless options but I have not messed with them yet.
I have not been able to get carplay to work at all
Update:
Follow-up:
Rhino got back to me and said "I'm going to double confirm with the technician about the navigation"
I asked them to also confirm the 2010-2013 harness as it is completely different than the 2014+ harness
They responded with "I will make sure to get all the following answered, will reach out shortly"
So we will see...Basically sounds like no one has a harness for 10-13's yet.
I registered an account and came out of lurk mode to post my thoughts on this headunit. I'm a new 2019 4r owner (two previous tacomas) and picked up the T9 two weeks ago, it's been installed for a little over a week.
The install went ok. There are no instructions anywhere to be found and after getting it crammed into the dash, the backup camera didn't work and the wireless signals for 4G and Wifi were terrible. Turns out that was my fault. The wiring harness is surprisingly involved and I had missed hooking up the backup camera. The wireless signal issues were because the 4G+ connector is actually for the 4G antenna and the "TV" connector is for wifi.
Fit and finish are ok, not factory but not bad at all. The biggest issue I had was some holes just aren't large enough for the screws and needed to be drilled a bit.
With an ATT SIM installed, I get....H+ speeds :( I'm not sure if this is ATT being jerks with the broadband APN and not being a known IMEI (they default unknown IMEIs to HSPDA instead of 4G) or if it's a band issue, but it's enough for things like spotify and maps to work.
WIFI is strong, but I have 5 APs in my house including one in the garage, so take that with a grain of salt
Speed is great, I've had no slow downs at all throughout the day. cold boot time is around 30 seconds, coming out of standby around 5 but the backup camera works immediately.
I've had several crashes and resets which turned out to be related to a bad USB thumb drive that would corrupt at random. Once I removed it and replaced it with a better drive, I've had no more weird resets.
The screen is making a terrible high pitched whine. It sounds like an inverter coil being overdriven, I've reached out to the vendor I bought it from on Amazon to see what they suggest. It's easy enough to block it out with music playing but it doesn't matter if the engine is running or not, the sound is coming directly from the screen.
I do infosec for a living so I have a dedicated gmail account assigned to this unit and I'll be digging into it (and watching its network traffic) over the next few weeks.
It has 2 bluetooth radios which can get a little confusing when you try to pair your phone or whatever. It does allow for one radio to be paired to your phone and one to an OBDII adapter (I'm using BlueDriver) without conflict.
Dash controls all work, CAN bus stuff is a little weird. There is a CAN bus setup inside the extra settings menu that I'm toying around with but it doesn't reset when you do a factory reset, so I'm a little hesitant to go too far. I have been able to do little things though like turn the power standby to a day and turn off that silly air conditioning status popup screen. I've also found where to turn off things like video playback if the vehicle is moving.
It plays loud. A lot louder than the factory non JBL+Nav that I had OEM.
Overall, I feel pretty happy for the money I've spent and the upgrade it provides. It's not perfect and I feel like if this had something like lineageOS available to it, it would be a no brainer. Having said that, baring anymore weird stability issues, I'll keep it even if the screen whines.
I'm on att dim and get full 4g. Works great
ShiftHarbor683
