Some calcs I did for total drag a couple years ago
Ron4RNevada
Some Calculations of Horsepower Required for a Medium Sized Full Time 4wd Vehicle at Various Highway Speeds.
All dimensions, measurements and calculations are for a 2004 Land Rover Discovery S with the following characteristics and modifications:
No external add-on devices such as roof -racks, lights, a-bars or winches.
Truck lifted 5 inches (3 inch spring lift and fitted with 265/75-16 tires).
Assumed a Cd (coefficient of drag) of .42 (based on typical pick-up with top shell).
Calculated fA (frontal area) of 42 ft² (6 ft wide x 7 ft tall).
Assumed a weight of 4600 pounds.
Assumed that the ratio between rear wheel horsepower and flywheel horsepower for a full time four wheel drive vehicle would be about 5:4 (multiply bhp at flywheel by 1.25 for bhp at wheels).
Calculations:
*1 - Rolling Resistance = 4600 lb x .015 = 69 lb. I actually measured this and it came out very close to 65 lb using the bathroom scale to push the truck in neutral, brake off on a flat surface. Then with the added resistance of transmission, transfer box and differential gears; 69 lb should be pretty close!
*2 – Air Resistance = fA x Cd x .00256 x mph² = 42 x .42 x .00256 x 4900 (70 mph).
10 mph = 5 lb
20 mph = 20 lb
30 mph = 45 lb
40 mph = 80 lb
50 mph = 125 lb
60 mph = 180 lb
70 mph = 221 lb
80 mph = 320 lb
*3 – Total Drag = Air Resistance + Rolling Resistance (69 lb).
10 mph = 5 lb + 69 lb = 74 lb
20 mph = 20 lb + 69 lb = 89 lb
30 mph = 45 lb + 69 lb = 114 lb
40 mph = 80 lb + 69 lb = 149 lb
50 mph = 125 lb + 69 lb = 194 lb
60 mph = 180 lb + 69 lb = 249 lb
70 mph = 221 lb + 69 lb = 290 lb
80 mph = 320 lb + 69 lb = 389
*4 –Brake Horsepower (bhp) at Wheels Required for Various Level, Highway Speeds. (Flat, perfect road, no wind, no curves and Steady Pace) = Total Drag x mph/375 x 1.25
10 mph = 2.46 bhp
20 mph = 5.49 bhp
30 mph = 11.40 bhp
40 mph = 19.86 bhp
50 mph = 32.32 bhp
60 mph = 49.80 bhp
70 mph = 67.66 bhp
80 mph = 103.68 bhp
So what’s the point? You say - - Well, for those trying to get a bit better fuel economy while navigating you 4600 pound, brick shaped, full time four wheel drive rig down the expressway at 80 mph; consider this:
At 80 mph it takes more than twice as much horsepower than it does at 60 mph!
At 70 mph it takes more than twice as much horsepower than it does at 50 mph!
OR – At 50 mph it only takes about 1/3 as much horsepower as it does at 80 mph.
Let’s assume that if you can get about 19 miles per gallon driving all day at 60 mph on a flat highway; what do you think it’s going to get when you put your right foot twice as far into the throttle to make it go 80 mph?
Now then; driving in hills, traffic or off-road; some different conditions do apply. But using only as much throttle as you really need really helps.
The point I make is:
On another thread this morning someone was complaining about Fuel economy driving from Las Vegas to Boise in a forty mph wind - -
If driving at 70mph and adding another 40mph head wind - the truck is seeing a total of 110 mph of wind speed. The formulas are above. Would you like me to calculate the horsepower required or do you want to do it?
BTW: The Frontal area for the '04 LR Discovery is only about 10% more than the '13 Toyota 4Runner. The weight is almost exactly the same. The tires I was running on the LR are the same as I am running on the SR5.
For your convenience:
68 bhp required at 70mph
180 bhp required at 70mph with 40mph headwind.
Even a 40 mph sidewind requires quite a bit of extra horsepower.
1Engineer -> Feel free to check/correct my math. As I approach 75 years old the mind turn slower.
Incidentally; here in northern Nevada where we have average wind speeds of 20 mph from the north-west and many days gusts of 40mph, I have learned that the only way to get decent driving a 4600 pound box with 42 square foot frontal area is to keep the speed at 60mph max.
This is good stuff! I dig the math! I've found that exposed front tires dramatically increases the difference between power needed at speed. Slowing down has a huge MPG benefit. Doesn't bother me personally, but something all of the sensitive folks should consider before adding weight and going for higher clearance.
Fuel economy in wind and on grades
Interesting read. Yes, engineers know that wind resistance goes up exponentially with speed. Something like to the square of velocity. That's net velocity of course. There's more wind speed in a head wind.
Another thing I notice is that fuel economy goes downhill fast when you climb a steep grade. I get a sense of this by watching my current fuel economy gauge and the distance to empty indicator as I climb. Going uphill requires fighting gravity. It requires a constant acceleration to maintain the same velocity, unlike a level highway which only requires a constant velocity without acceleration. Isaac Newton realized the relationship between velocity and gravity and created calculus to explain it.:bored:
It helps with fuel economy to slow down when climbing a steep grade.
