3wbdriver
Awesome racks system. Shipping to Hawaii probably kill me!
You might be surprised. It only weighs around 75 pounds, and other than the 8' length the box dimensions aren't bad at all because it all bolts together at your place.
We used ARB universal brackets on ours. ARB part # 813402.Those of you that have an SSO roof rack, curious what types of mounts you used for an awning
Sent from my Pixel 2 XL using Tapatalk
We grabbed it at the hardware store. Just snapped a photo for reference. It's 7/8" long stainless steel carriage bolt w/ washer and nylock nut. I don't know specifics about thread count and diameter.Do you have a link to the hardware you used to attack to the cross bars?
We grabbed it at the hardware store. Just snapped a photo for reference. It's 7/8" long stainless steel carriage bolt w/ washer and nylock nut. I don't know specifics about thread count and diameter.![]()
Perfect. Thanks!
Oooh I like that better and how it sits lower. I'll have to snag a couple pair of those to do the same. Good call.I used Rhino Rack mounts on mine. I think I paid $55 per pair, and since the ARB 2500 recommends 3 mounts I just used 2 pair. I mounted them with the long legs down to get the awning a little lower.
And I recommend you loosely mount whatever you use to the awning first and then mount it to the crossbar. On my setup it was pretty tight getting the bottom bolts started on the lower positions so I had to take it all off and go that route. Once I had everything lined up nice I tightened the upper bolts to the awning with it on the 4R, then removed it to tighten the lower ones. Then I had the wife just hold it in place until I got 1 crossbar screw started at each end. That held it well enough I could finish without her help. And yes, I'm using 80/20 hardware.
Are these what you purchased and did it come with the mounting hardware for our crossbars?
#43100 - Pioneer Batwing And Sunseeker Awning Bracket Kit | Rhino-Rack
If you go to buy these you may look on eBay and try to utilize today's coupon code 'PICKSOON' to knock 15% off. I found them for $45/set out there and the coupon worked on em. I'll be ordering some soon to replace my current method of attachment. I like the look of the RhinoRack ones much better.
Correct, 47” length. Call them and say you want the same as for Prinsu rack but 1030. They will know all the other options.
I went with 1020 as all was set (though SSO sent me few additional 1030 too)
What's the difference between the 1030 and 1020?
Yeah, you still mount the tent on the crossbars, you just pull the crossbars off the rack to do it. Otherwise your gonna need some real tiny hands to tighten those nuts on the bottom of the crossbars.
