Sway A Way CO's are loose at full droop
xcmountain80
Good evening,
I have a 2002 4runner auto 4WD and installed a set of SAW 2.5" CO's last year about this time IIRC. The other day while rotating the tires I noticed an audible jiggle, when I checked it out the entire CO assembly floats a bit on the lower mount (LCA). The spacers included with the CO's were a (2) thin an (2) thick. I'm using an extended bolt though same dia. and contact surface as the stock length bolt.
Thanks Aaron
7ron
