Switch Pro 9100 Vertical Mounting Solution
Hi,
Interested in this. Can you mail to Canada? What would the charge be? Will the power cable fit under the tray and behind the fuse box down to the battery?
Wayne
Hi Wayne, here is a picture of the power cable in that position. Without really getting up and in there to run it, I cannot say 100% yes, but it sure looks like it. Sorry for the dark picture, went out at night to check for you.
I don't see why I can't mail to Canada, Please PM me your email and postal code and I can check Monday with the Post Office if you're still interested. Would that be ok ?
Hi,
Wayne
Wayne, I communicated with you via email, but wanted to post up so others asking knew that shipping to Canada is about $40.00
How does this compare to the Overland Equipped? That’s what I’m currently running with a blue seas fuse box. Ability to run different units?
I’m not to familiar with Overland Equipped. But looking at their product it’s not designed to mount a switch pro. Am I wrong?
This particular mount is designed to mount the switch pro as it was intended to be mounted, vertical.
I would love to run one of these but I already have my ARB Dual Compressor in that spot on the Slee mount. That spot seems to be the most popular place to mount anything under the hood.
The product looks great and I am sure it'll do well, just sad I can't utilize it.
The Fuse Block Mount Tray will be available within a month or so, but as tomb_rnr says, Their product is not for the Switch-Pros SP9100.
I believe you are correct. I looked at the product as well... unless I am missing something. Thanks for answering.
Your install looks like you did a great job ! Nice clean 2019... I like it !
Thanks for the feedback ! Yeah that ARB is a beast for sure. I do not think there's any additional room after that install.
Here is the finished install.
I am interested in purchase as well. 10 or 12 circuit blue sea. What will the pricing look like?
Just for this version of the Mount Tray, $100-120, but I'm hoping to keep it lower if i can (Mount Tray only, BS items will be additional).
Here is a possible layout for the Fuse Block version in the works. It will accommodate the Blue Sea 6 or 12 Fuse Block with pre-drilled holes and one circuit breaker as shown. There would be slots on both sides of the Fuse Block (not shown).
Any thoughts or comments ?
Fuse Block Mount Tray in Stock Soon
Hi, so the Fuse Block Mount Tray will, as pictured above, be available in a couple weeks. The only thing not shown in the photo are the slots on the left and right sides of the fuse block.
Fuse Block on Current Mount Tray
I had a request to see if the Fuse Block would fit on the current Mount Tray. If you wanted to drill holes, this is what it would look like...
I have a BS 12 circuit w/ negative fuse block and a 10 gang busbar. I came across your thread today and was curious if they'll work on your mount?
If so, how can I order one? Thank you!
So, this one pictured is the current Mount Tray available designed around the Blue Sea BusBar (as pictured - holes drilled) and the Terminal Block - the Blue Sea Fuse Block is covering that part. If you drill the holes for it, there you have it as pictured.
Additionally, the Fuse Block Mount Tray that is being manufactured right now will have the holes drilled for it and a slot on either side of the Fuse Block if you can wait a couple weeks.
If you want this one, PM me your name and email address and I can send you an invoice to pay and I'll ship it next day generally depending on when its ordered/paid.
Do you have a rough ETA on the new tray? I will most likely hold out for that one. I like the idea of being able to keep all the cables organized on both sides. :dancin:
Rough is 2 weeks. I am hoping for sooner. I'll definitely be posting here when they are available.
Should be getting the Fuse Block and the Blank Mount Trays in next week sometime.....
Thank you for those that have purchased the Terminal Block Mount Tray. Please post pictures when you get it installed !
