The 3rd Gen All Questions Allowed Thread
Status
Not open for further replies.
Totally unrelated to maintenence, any of you other Facebook users able to find the 3rd Gen Mafia group? Looks to have been zucked.
Bought a 1999 SR5 last week. Diagnosing front end steering tracking problems and clunks over bumps today and came across the part number on my front strut. I’ve been curious if these are the stock struts or not as the front end looks taller-ish than others I’ve seen, and Google isn’t giving me anything so I’m asking y’all’s help. On the shock body, behind the coil it says from top to bottom “315, warning do not heat or open, install this end down, made in USA PO31L1D” I actually can’t tell if the O is a zero or not but neither turn up on Google. The shock is blue. Can anyone help me identify it?
99 Tall coils on 2wd
Since the 99 Tall coils are meant for a 4wd, if I put them on my 2001 2wd would the front end possibly end up higher than the back since there's less front weight on the 2wd? I'm guessing the 4wd coils are a little stronger/stiffer to accommodate more weight?
If you think that could happen, do you think it would be enough to be obvious at a glance?
This is just a daily driver, no real offroading. Just a few light camping trips per year.
And if anyone has actually used the 99 Talls on a 2wd, please chime in and let me know if you encountered any problems with the install or later on. I've found others asking about it on these forums, but can't find any posts after they did it. Thanks!
A certain clown managed to get it shut down and opened up another page under his own terms.
I believe the new page has the same name
ive got a 99 v6. does anyone know if the studs on the exhaust manifolds are the same as the studs used in the collectors/crossover pipe?
also, is it a good idea to replace them if they came out with the nuts?
I have a 3rd gen 3.l diesel surf which shorted out while driving. Positive battery clamp broke and touched the hood. Repaired the harness as best as I could had to run a new wire from the starter to the key switch. It starts however switches off as soon as it is placed in gear. It will start in park or neutral but the moment you put it in reverse or drive the engine immediately switches off.
First look over my new 99 SR5 - spotted some oil behind the transmission (?). What's leaking? Will get some better photos.
if that's motor oil then based on the location it's probably rear main seal or the oil pan. it could even be just accumulated mess from regular oil changes or a leaky oil filter.
if it's not motor oil, then the type of fluid will tell you exactly whats leaking (tranny fluid, power steering, etc.). It all looks pretty much the same once it's dirty.
Thank you. Yeah I'll give it a clean off and see what accumulates. I need to pass an out of province inspection, hoping a good de-grease and clean does the job.
gear ratio
Hey guys,
quick question here. How can I tell the gear ratio of my 3rd member when it is out of the truck? I have a e-locker rear end I got a month ago and I am trying to figure out what gear ratio it is. Since its a auto 1998 4runner it came off it's most likely a 4.30 ratio but I want to make sure it is or isn't. Obviously it's not on a truck or anything so I can't do the driveshaft wheel spin test. I currently have the 3rd member out of the housing, would I just count the teeth on the ring gear a certain way?
Thanks,
-GH
Hey guys,
Thanks,
-GH
With the third out of the housing just count the ring gear teeth and pinion gear teeth, then look up the ratio
Could be the valve cover gasket/half moons, oil pan gasket, or rear main seal. Crawl back under with a flashlight and take a look at the back side of the heads. It's really common for the valve cover gaskets/half moons to leak all the way down and drip on the rack, skid plate, and ground.
Hey guys,
Thanks,
-GH
Ring gear teeth divided by pinion teeth is your diff gear ratio
1/2 vs 3/8 Impact and Deep vs Shallow socket set?
I'm about to replace all shocks & springs and hit LBJ's at the same time.
I've only done oil changes and front brakes so far so don't have a lot of tools yet.
I figure an impact wrench could cut down on time & headaches, at least for lugnuts and lower shock bolts. If I only have one impact wrench for this and future projects, what size should it be? I'm guessing a 1/2" can do everything a 3/8 can and more, except its a little bulkier. Is that the one to go wtih?
Also Harbor Freight has a 13 piece deep impact socket set on sale for $19. Has most sizes I'd need except the 12mm for some reason.
If I only bought one socket set, should I go deep or shallow? Like the 1/2" impact, I assume deep sockets can do everything shallow can except fit in some tight places? But maybe I should stop thinking for myself and listen to you guys with more experience!
And if shallow is slightly better overall, is $19 such a good price that i should go ahead with the deeps?
Status
