Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We appreciate the opportunity to address your inquiry and we apologize for any confusion the two publications caused.
Please following the recommendations in the owner's manual.
Your email has been documented at our National Headquarters. If we can be of further assistance, please feel free to contact us.
Sincerely,
Mick C.
Toyota Customer Experience Center
Customer By Web Form (Name Removed) 10/15/2016 10:40 AM
Good Morning,
I have what I’m hoping to be a quick easy question.
The “Toyota 2015 4Runner Warranty and Maintenance Guide” located at
http://www.toyota.com/t3Portal/document/omms-s/T-MMS-154Runner/pdf/2015_Toyota_4Runner_WMG.pdf states that to “Lubricate the propeller shaft spiders and slide yokes with lithium-base chassis grease and the double cardan joint with molybdenum-disulfide lithium-base chassis grease, and re-torque the bolt…”
The “Toyota 2015 4Runner Owners Manual (OM35B18U)” located at
http://www.toyota.com/t3Portal/document/om-s/OM35B18U/pdf/OM35B18U.pdf
States the following:
Chassis lubrication
Propeller shafts
Spider: Lithium base chassis grease, NLGI No.2
Slide yoke: Molybdenum-disulfide lithium base chassis grease, NLGI No.2
or lithium base chassis grease, NLGI No.2
Basically the warranty and maintenance guide says two different greases are to be used, while the owners manual says one can be used, which one is correct and which is followed (best practice) at dealerships?
