TRD Pro Suspension Availability
ChrisKimmelshue
Do we know when the TRD suspension kit will be available to purchase?
I've gleaned the following part numbers from various threads:
Front Left
PTR-13-35120-AB
MSRP: $465.27
Front Right
PTR13-35120-AF
MSRP: $465.27
Rear
(2) PTR13-35120-AC
MSRP: $365.13 Each
(2) PTR13-35120-AE
MSRP: $94.24 Each
Springs Front
(2) PTR13-35120-AA
MSRP: $159.64 Each
Pulling up the parts numbers on Google shows that these parts are (also?) for the Tacoma. Can anyone confirm these part numbers?
If those numbers and my math is right that's $2076.32. That seems really expensive for that type of set up.
I'm "assuming" the rear springs are $94.24 each? If so, you can save that money because they are the same as stock springs, which brings the total cost down to $1887.84 (again if my math is right). Still seems rather high?
To each their own I guess.....
Front Left
PTR-13-35120-AB
MSRP: $465.27
Front Right
PTR13-35120-AF
MSRP: $465.27
Rear
(2) PTR13-35120-AC
MSRP: $365.13 Each
(2) PTR13-35120-AE
MSRP: $94.24 Each
Springs Front
(2) PTR13-35120-AA
MSRP: $159.64 Each
:confused:
Guys,
Look here for the pricing and availability.
Click on the hyperlinked price!
http://www.toyota-4runner.org/5th-gen-t4rs/176518-trd-pro-parts.html
kpd1999, you are correct, the original rears springs are used on the T4R, but the second number he has indicated for the rear are the TRD Bracket for Remote Reservoirs.
That money will easily buy you Icon, Radflo, Sway-a-way, Walker Evans, King, or Fox.
Surely, these parts will be discounted. I posted the MSRPs.
I had read somewhere here on this forum that the "kit" is in the $1200 to $1500 range depending on where you buy. That seems reasonable to me for a "Factory Approved" lift/leveling kit.
I'm sure there is a "better" kit out there for the money, but some folks like to go the OEM route.
I prefer OEM too but we are talking about bolt on suspension hardware, little or no modifications necessary, you can easily RTS whenever you want. It just seems expensive for what it is, ie a non-rebuildable shock for $330, that's all.
You did catch my point :) I simply used those as a cost comparative example, you can also get a dozen other quality kits for less. Not intended to disuade anyone just saying there are comparative/better options for your money, then again it is your money :D
Will Toyota still honor my warranty if I install the TRD shocks/springs?
Yes! As long as it is purchased from Toyota and have a receipt (not from some third party source) & installed correctly.
These part numbers are incorrect, don't order them unless you have a Tacoma!
TRD - Parts Search
From the pictures shown from the final assembly plant you can see the part numbers are different...
The numbers listed above were taken off of the pictures of the prototype vehicle. So they could be wrong.
Pictures were posted in the other thread with this number on the shock...
PTR13-89150
I'm glad I asked. Would you kindly post the correct part #s here?
Reposted from saker:
I just got this reply from JM4Runner (one of his latest posts with pictures: http://www.toyota-4runner.org/1797088-post1177.html)
"I actually don't do installs for the company, but have access to alot of info. The Kit comes completely together. Below are All the corresponding TRD part numbers pulled from a work order. Hope this helps.
TRD Pro Suspension Kit - PTR13-89150"
TRD - Part Detail
Retail MSRP of course.
Here is some updated info on the above subject.
I will post the full conversation with the exception of any real name(s).
JM4Runner works at one of the ports where the TRD Pros get their final upgrades.
Saker said:
JM4Runner said:
Saker said:
JM4Runner said:
Saker said:
JM4Runner said:
Saker said:
JM4Runner said:
Saker said:
Hello JM,
I am just trying to gather as much info on the suspension upgrade as possible to achieve the best pricing.
If this is your area of install, or can help with the following question, does the port receive the complete sets of coilovers (coil & strut or shock assembled) and rear shocks w/ reservoirs, and also receive the brackets for the reservoirs?
There are posts that indicate the part #'s for the individual parts, if I read them correctly.
Shocks
Front:
Left-PTR13-35120-AB Price: $329.17 Each
Right-PTR13-35120-AF Price: $329.17 Each
Rear:
Left/Right-PTR13-35120-AC Price: $263.41 Each
Remote Res Bracket-PTR13-35120-AE Price: $67.99 Each
Springs
Front:
PTR13-35120-AA Price: $115.16 Each
If this applies, do you possibly have the part #'s for the struts w/ coilovers complete as you receive them?
Thanks,
XXXXX
I actually don't do installs for the company, but have access to alot of info. The Kit comes completely together. Below are All the corresponding TRD part numbers pulled from a work order. Feel free to throw in your thread, don't want to jack it, but would take a mention ;) Hope this helps.
TRD Skid Plate - PT938-00140
TRD Shiftknob - PTR57-34140
TRD Pro Exterior Badge - PT413-00150
TRD Pro Floor Mats - PT208-89150-20(Personally I don't like these, but comes with the truck at no extra expense, like other mats do)
17" TRD Pro Alloys - PTR20-35110-BK
JM,
Do you know if these parts are in fact the replacement parts or parts to order instead of the kit # PTR13-89150 for the 4Runner.
Are these good part #'s for the TRD Pro Suspension for the 4Runner or do you have access to that info?
Some are saying these are for the Tacoma Baja Suspension and not the 4Runner. Can you help me clarify this?
Shocks
Front:
Rear:
Springs
Front:
Much appreciated!
Thanks,
XXXXX
Looks like they are the individual replacement parts opposed to the entire kit. To the best of my knowledge, the Baja Tacoma and the TRD Pro suspension for the Taco and 4Runner are the same. Can confirm monday, but pretty positive.
I will wait on your reply.
I know from pictures, the TRD Pro Suspension Kit - PTR13-89150
the coils indicate PTR13-89150-AA (on one picture) installed on a strut PRT13-89150 LF.
That's what people are seeing on the Kit pictures and now the above part #'s are in question whether they will fit. Some are saying these part #'s were gleened from the prototype TRD Pro 4Runners in testing.
Again, I will wait on your reply, as the dealerships can offer me no help!
Thanks,
XXXXX
Ok so the TRD Pro suspension and Baja are the same, but as an entire kit for the port installs the part number changes compared to individual replacements. I have a feeling that the pictures floating around causing so many questions is because Toyota created monsters during testing. This is just a belief and not factual knowledge obtained, but because we see some initial pictures with sunroofs, and KDSS, I think Toyota just used TEP models with and without KDSS, but had the paint color changed for Pro specs. Once tested and all was said and done, they determined no Sunroof and no KDSS for the final build. As for the suspension, they had a tested and proven suspension from the Baja and used that. Hope this helps.
Thank you for your research in this!
Would you object in me posting your response to my questions regarding this?
Sincerely,
XXXXX
The part verification is the only factual information. The rest I really just deduced. Makes sense to just paint a vehicle a different color and change the front end, then proceed with the full build once tested. I don't mind though as long as that's clarified lol.
Thanks!
ghengiskhan
