Tyler James Inc's Ultimate '01 SR5
Are your fog lights Toyota or aftermarket? Many aftermarket parts, especially lighting stuff, has generally been not all that great.
Mine are OEM. I got them from [MENTION=124101]Chim[/MENTION] from his '02, as well as the whole front bumper. Yeah, I would be hesitant to go aftermarket too. There are constantly 3rd gens being parted on the PDX CL- I wouldn't think it would be too hard to find a set for $100 or so.
If there was a Milli Vanilli cd left in there it wasn't mine ;)
Asking for a friend, right? [emoji23]
I've tried hooking up several different aux input adapters in the external disc changer port on the back of my single disc factory radio but none of them worked. Now I'm thinking it my work on the 6 disc changer you have.
Oh serious? Interesting you mention that, because I was planning on getting one of those aux adapters. I don't remember the site I was going to order from, but they were the only place that I have found to have a lightning cord that has aux input and +12v for charging. I want a hardwired cord for my phone so I can charge it and listen to music with it. I'm sure I could get a fancy adapter to stream over BT, but $60 sounds way better than $260.
Edit-
Whoops, thought you were in WA. Well if you find a set on the PDX CL, I'd be willing to grab them for you and ship them. [MENTION=77045]99 sr5 highlander[/MENTION] could probably get you a nice set too.
These are some of the aux input adapters that I tried from amazon. They have a USB port for a lighting cord & an aux input. It plugged right into the back of the CD changer port on the factory stereo. It would charge my phone but I wasn't able to play any music. All the products I've tried are listed to work with the 3rd gen but I'm thinking when the manufacturer states it plugs into the OEM CD changer port, maybe they mean the stereos with the built in CD changer? If you find something that works let me know.
APPS2car
APPS2car bluetooth/aux/usb adapter
Yatour bluetooth/aux/usb
EVAPLUS aux adapter
Edit-
Lol. I used to be. Still have family in PNW. I grew up in Tacoma Washington then my family moved to Georgia in the early 90s when I was a kid. For sure, if you come across a set of OEM fog lights I'd most definitely appreciate a heads up because the OEM fogs I've looked at locally were all pretty crusty.
Drilled my core support to lower the rad-
Whoops [emoji19]
Trimmed the bumper side supports-
Finally pulled the DRL pin-
Know what's incredibly convenient? That just happens to be fed from "gauge" fuse. You know, the one I've been trying to figure out where to tap into for my clutch start cancel button?! [emoji322]
So that was cool.
In case anyone happens to think my shit is clean because I work in an office and park in a garage-
And a pic of my non-PRND2L multi-mode cluster while my lens is still clear [emoji23]
Got my flags cut and stuck on [emoji631] Decided on gloss this time-
You mean you're not an investment banker with a huge salary and bonuses that make some third world GDP's look small? lol
Trucks looking good man. You got a lot of stuff done is a pretty short time.
[emoji23][emoji23][emoji23]
No, I totally am [emoji6]
Thanks man. My '97 was dialed as far as suspension/handling and cleanliness, so I'm goin hard trying to get the '01 up to snuff.
Speaking of which-
Gross AF [emoji30] It really didn't clean up great, so I didn't get pics. Hopefully I'll be able to eventually get it cleaned up, but it looks like mold, so I should probably just replace it.
Carpet is coming clean nicely though!
I think I'm gonna go to the 4th notch on the fronts, and put the center bumps back in the rear. My priorities are screwed up too; I still haven't gotten an alignment, and my tires are already stepping *♂️ Still drives and tracks great from my home alignment.
I think I'm gonna go to the 4th notch on the fronts, and put the center bumps back in the rear. My priorities are screwed up too; I still haven't gotten an alignment, and my tires are already stepping *♂️ Still drives and tracks great from my home alignment.]
As long as your not driving tons of miles get the alignment done when your done.
I have the Taco D558 Billies. Since stepping it up to 295/70r17's I'm seriously considering stepping it all the way up to notch 3. With the bumper and winch it should tame the ride out a bit but I hate putting that much pre-load on. Worse case is I reverse it and do a proper tub.
As long as your not driving tons of miles get the alignment done when your done. I have the Taco D558 Billies. Since stepping it up to 295/70r17's I'm seriously considering stepping it all the way up to notch 3.
Yeah, obviously- that's why I haven't gotten it aligned yet. Hoping Les Schwab will put my strut in their clamp and move my perch for me. I hate using the spring compressors and taking it all apart.
That's a great size tire BTW. I would love a 295/75R17 [emoji12]
What a pain! Finally got the new steering rack bushings installed [emoji1598]
I remembered them being easier on my '97, but after I'm all done with a project, I tend to forget immediately how pissed off and frustrated I was during the process.
The only real PITA was pounding out the OEM rubbers. I did it with the rack in place, so I didn't have space to setup a clamp/press. It still wasn't too bad, just took a while. It was 100* out, but the concrete was cool, and kept me surprisingly comfortable.
I used the Energy Suspension kit again. I chose black, because I'd rather things appear stock vs aftermarket.
I'm a little less lowrider now. Went from perch 3 to 4 of 5 on the Tundra fronts. Still on '99 tall coils. Idk how much lift that is over stock, but it's about 22.25" to COH. I think that's still only about 2.25" of lift?
Everything good comes in a red and white package [emoji41][emoji12]
got enough spare keys?
I think I do now [emoji12] The plastic top key that came with the rig had a broken top link, so there is a hole drilled in it- ghetto. I also wanted to have my locksmith make a perfect version, to help preserve my ignition/lock cylinders [emoji1360] The perfect versions are worlds different than the hardware store/dealership cuts.
What are you using to clean the carpet?
Simple Green, a microfiber cloth, a brush, and a bucket of hot water [emoji1360]
Can you elaborate on this perfect version key?
I thought the best way to go was a dealership vin cut key.
Me too! Which is what I did for my '97 when I got it. When I was getting it ready to sell, I finally fixed the finicky ignition. When I say "I" fixed it, I mean I had a locksmith fix it. When I contacted him about the repair, he mentioned "I'll cut a perfect version of your key, which will help prolong the tumblers" I'm like "uh, I just had the dealer cut two new keys, and I've only really used one". He said "these will be much different- I guarantee"
I'm thinking to myself "okay dude, whatever".
I go to pick the ignition cylinder up, and he hands me the keys. I compare them, and was about in shock- the new key has sharp points on all the spots that depress the tumblers. I ask him why it's so different than the keys the dealer cut from the VIN, and he says "well, because their machine is about $5k, and mine is $60k."
I wish I could post pics, but- for the security of the new owner of the '97- I can't do that.
When I first got my 97 the owner handed me three keys. All where worn and rounded. They'd start the rig sometimes, sometimes they'd be a real PIA. I was all set to get a new ignition cylinder but put a call into a local locksmith. He told me to stop by and he'd see what he could do.
He used the vin to get the proper key on the tumblers. Then he made a "test" key. He explained that about 80% of the time it works. When it doesn't he uses the test key fine tune it by looking at the pattern on the teeth. Well, that "test" key worked perfectly. I had him cut 3 more on the spot. All totaled for his 30 minutes of time and 4 keys was 40 bucks. Haven't had any key issues with my rig since.
[MENTION=84643]JBurt[/MENTION] I found a pic of what I mean by there being points that depress the tumblers further-
Basically, my brand new, fresh cut key from the dealer looked like the worn key above.
I guess the good machines are smart enough to estimate what the original bump used to look like and overcompensate, versus the cheap ones that just copy paste.
