Manual swapped the '01 cluster-
Single-mode J-Shift. To be honest, I wouldn't mind the single-mode straight-shift. I never got to try it in my '97, but I'm pretty sure you can get 2LO pretty easily on those. If you un-plug the position SW on the shift rail, and shift it in to LO- the "computer" won't know to actuate the 4WD rail, but you manually just went into low range. You can then get 4WD by pushing the button...Which transfer are you replacing your multi-mode Straight-Shifter in your 4Runner with?
Maybe?Am i missing something?
Maybe?
I have electric ADD.
The rail position SW on the J-Shift will still close the circuit, which will tell the 4WD computer to engage ADD.
And, just in case you thought your seat belt receptacle had black lettering- it does not.
I thought I was the only weirdo who did this!! I have those same towels from Costco. Can't beat them. Once they're completely dirty, I toss 'em.
Man; I was set on the simplicity of the j-shift, but now you have me re-thinking it. It would save me money in having the driveline lengthened too. But then my front would need to be shortened... as it is, I have a manual front shaft that's the right length for the j-shift.Wouldn't it be cool to keep the multi-mode transfer case in? I mean you have central diff lock on it, which you can unlock and drive on pavement at highway speeds?
Thanks man! I need to do that too. Did you use any kind of detergent, or just hot water?The seat belt now retracts into the seat belt retractor on its own. Love the work so far on the new rig.
Man; I was set on the simplicity of the j-shift, but now you have me re-thinking it. It would save me money in having the driveline lengthened too. But then my front would need to be shortened... as it is, I have a manual front shaft that's the right length for the j-shift.?
Man; I was set on the simplicity of the j-shift, but now you have me re-thinking it. It would save me money in having the driveline lengthened too. But then my front would need to be shortened... as it is, I have a manual front shaft that's the right length for the j-shift.Thanks man! I need to do that too. Did you use any kind of detergent, or just hot water?
Okay, cool! I saw that little opening between the bracket and block, and was wondering if that would work. In that case, I'll pick one of those wobble extensions up tonight too!I used a 12" long 1/4" wobble socket extension with a short socket and was able to reach the rear tensioner bolt while lying on my back and going underneath the 4runner.
Haha thanks Steve [emoji5]Since you are changing driveline length just go ahead and put in dual cases. I would like to see how I should have done it.
What was the date stamped on the thermostat that you pulled out? That'll tell you whether it was original... I bet it has been out once before.First TB job, so that's where I got after just under 2hrs. Interesting there is a current thread on the "jiggle valve", as mine was probably factory installed, and was clocked so the jiggler was at 12 o'clock.
