Hit a milestone that gamblers and believers alike will appreciate!
Installed Ironman Nitro Stage 2 Lift. So nice to add clearance and get rid of the drivers side lean!
Came out to Vegas to gamble a little
Still T-Shooting the 3 Pax windows NOT being able to close from respected door controls. The lockout switch is working as supposed to. The switches are physically unable to be pulled up to close. Tried resetting per OM & from suggestions on-line to know avail. Hate to have to go to dealer for a re-set. But starting to think I have no other choice
Installed a pair of Victory 4X4 crossbars and mounted the Weboost antenna on a Rhino Rack folding mount.
Next up traction board mounts.
doing prep for paint. missing transmission skid & right slider. 4xinnovations giving me the run around.
purple zep degreaser, orbital sand, degreaser again. prime tomorrow then paint on monday.
Installed remote start. I've taken apart 4Runners way too many times, so it took me less than an hour. Helps that it was a plug and play system with only one wire requiring soldering.
Unfortunately I'm still having issues getting the cellphone module to work, but oh my gosh is it an amazing feature to have on any vehicle! Working with the manufacturer to figure out what I didn't wrong.
Here are the systems by the way:
Amazon.com: Start-X Remote Starter for Toyota 4Runner (Key Start) 2010-2019 || Plug N Play || 3 X Lock to Remote Start: Car Electronics
Amazon.com: CARLINK ASCL6 Remote Start Cellular Interface Module Allows You to Start Your car from Your Phone 1 Year Included
Sent from my SM-G981U1 using Tapatalk
Interesting find... seems to work with OEM key fob, which is a plus
Yeah, works with the 3X lock click no problem. Amazingly easy to install! I want to have the cell phone option though but it's giving me issues at the moment. I'm hoping for an easy solution. Soon will see.
How does this compare to the accessorides version. Is there a monthly subscription with the cell phone start capability?
I didn't do these today, but I did do them recently.
I got a couple of these Duragadget tablet headrest mounts from Amazon. They work with the Nintendo Switch nicely. There's a little learning curve to getting things set up right, but it's stable enough once you get used to it. I tried it out myself while my dad was driving my truck around town, and it worked as well as you could expect. I was playing Super Smash Bros. Ultimate, and at least for me the characters were probably too small and the action too frantic for me to view totally comfortably while moving. I could see myself having a better time with something that has more simple graphics like the Sega Ages Outrun from the eShop or something.
I went with this one partly because it has good access from all sides for power connections. I didn't show it in the pictures, but I was able to plug a USB cable from the bottom of my Nintendo Switch to one of the rear USB power ports in the back of my 2020 4Runner, so my Switch was able to stay topped off through the whole trip.
Amazon.com: DURAGADGET Sturdy in-Car Adjustable Headrest Mount for New Nintendo Switch (Console with Joy-Con Attached): Computers & Accessories
The stock 4Runner headlights are pretty bad. These are some good replacements. I only drove at night with them once so far, but everything looked really clear through my windshield.
These videos from TRD Jon on Youtube helped me to decide on these headlights. A link to the Lasfit online store is in the description of the videos.
Installation: https://youtu.be/Cy1v0nCBnqY
Two week review: https://youtu.be/GYiQyd-uCvk
how does that we boost help ???
I can tell you it works without question and works as advertised.
Many areas around up and down the 395 and the CA desert have super weak reception that gives me a "no service" signal or 1X/3G. With the Weboost on in those same areas I get 3/4 bars LTE.
Now when I get high enough in the Eastern Sierra the cell towers are so far away the Weboost doesn't do a thing.
I can tell you it works without question is works as advertised.
gotcha ... thanks for the input
Installing Front Runner QD Tent Mounts to Rhino Rack
Hello all,
First of all, I am no expert and this modification was not specifically recommended by Front Runner or Rhino Rack. I did this at my own risk and if you choose to try this modification, I am not responsible for any failures.
I am posting this because I struggled to find any information on what I was wanting to do. My goal was to see if anyone had mounted a RTT to a Rhino Rack pioneer platform using Front Runner's QD mounts. If you haven't checked them out, they are awesome, but they are meant to go on Front Runner racks, not other racks. Because of this, the mounting hardware was unusable with my solution to mounting on the Rhino Rack.
Quick Release Tent Mount Kit - by Front Runner
My solution was to buy the following Rotopax mount from rhino rack because it included the plates that fit into the mounting grooves of the rack.
I did not use the bolts from either the Rhino Rack mounting kit or the Front Runner kit. The reason is I wanted stainless steel bolts for the added strength and the rhino rack bolts were too small. I ended up going with a 3/4" stainless steel button head bolt with M8 x 1.25 threading. In the picture, left is the new bolt, right is the bolt that comes with the rotopax mounting kit.
Because of the difference in size, I used a drill press and a 6.9mm or 17/64" drill bit to drill out a hole big enough for tapping with an M8 x 1.25 hand tap.
Lastly, I used the bolt with a split ring washer and mounted the Front Runner mounts to the Rhino Rack pioneer platform.
The mounts are super strong and I have no doubt it will be strong enough. I can mount and unmount my tent by myself in only a couple minutes. It is absolutely worth the price of admission. Let me know if you have any questions!
Great post. Definitely going to be looking into this. Thanks
Sent from my Pixel 3a using Tapatalk
Installation: YouTube
Two week review: YouTube
Do not use those LED bulbs, they are worse than your stock headlights. I promise.
