Replaced the AutoZone battery with a massive capacity Diehard Platinum Marine battery. This it the mother of all batteries. And yes, it fits...barely. I had to reroute a few cables. The stock battery holder does work with this.
I opted to do this instead of the dual battery setup. I can run my ARB fridge all night and the truck will start the next morning.
New battery by VisualUniverse, on Flickr
do you have any information on the battery?
Installed my Light Racing UCA's today. Separating the ball joint on the passenger side was a MF! The driver side might have taken 15 minutes. Thanks to guys that posted tips. I was able to do my driver's side without having to do anything to the battery. From the little bit i have driven since finishing them i think i can tell a difference in the right quality, for the better.
How difficult/confusing were the headlights and baking?
It was pretty easy, just time consuming. The hardest part for me was taking off the plastic blinker cover (inside the light) without breaking any tabs. If you go slow, you should be fine. I've never done anything like this before and am pretty happy with the results. No leaks yet - fingers crossed.
I almost rolled it a few times. Well, it sure felt like I was going to roll it.
Went on some trails in Utah.
too hardcore for me pops.
I understand your point of view. I did purchase this as a D/D, and to use it for what it made to do. Just at times, I might end up running into opstickles,
that are un for seeable, and to late to turn around, in my adventures of where I'm going.
Went on a adventure this weekend, no damage this time. Tested the new tires and up grades from winter. Only got to use the winch for a line for the tarp for bad weather.
It failed the hail storm though. Other than that, gave it all kinds of off roading test, and mother nature, good to go.
whered you run into that weather? I know the storm is rolling in but not that bad.
Ill be testing mine out this weekend at Almanor.
Check out on the off road section. GOLD LAKE RUN.
All kinds of things didn't go the way we expected. Will be posting pictures there later, along with others.
I ended up in Downieville.
Quick question, what's the easiest way to see if I have the bigger sport edition brakes on my 03 limited? Is it as easy as measuring from the edge of the rotor to the inside of the rim?
The calipers have a stamped lettering on the side facing the vehicle. WG is the stamp for the smaller brakes. I can't remember right now what the other letter options are that indicate the bigger size. I could look it up but I'm sure someone can pop in here and let you know.
Well it wasn't today, but it was recently.
Headlight retrofit done! Thank you Addison (Rickashay) awesome job.
null_zps8173cba2.jpg~original
Plasti dipped my grill as well.
null_zpse3841885.jpg~original
Where did you find the projectors? Are they still 9006 bulbs? They look great![/QUOTE]
Not 9006 anymore they are now D2S Philips 85122+. I got the projectors through a group buy on Tacoma World. (The Retrofit Source). Thanks for the compliment.
goddesszilla
