Discovered a leak in my power steering low pressure return hard line today. There goes $120. At least I'll be able to exchange my PS fluid.
:hurt:
Haha, doing my headlights today if I can trust the power to stay on for the baking process. Actually works out well, I got moisture in mine because I didn't re-seat a bulb correctly about a week ago, so I can dry it out too....
Which bumper did you go with?
Just a painted replacement bumper from ebay
Took the backroads home today. :)
Sent from my LGUS991 using Tapatalk
Haha It's surprisingly simple.
Rigid's use what is called a deutsch connector and your factory is a 9006 connector. Look for the splitter and bingo! :)
Bought from these guys who have great products and GREAT customer service. I ordered expedited shipping and they contacted me saying it would be less money if I just did regular shipping and would get there in the same amount of time.
Link to Splitter Plug-and-Play LED Light Adapter Harness H10/9005/9006
Thanx brotha,
Appreciate that bit of info...that's awesome. So for a light bar you just need one, a pair of pods you need two, that seems to be the deal?
And if I don't have rigid lighting then I need to find where I can purchase a deutsch connector and wire that to the end of my light bars or pods wiring..correct?
and as far as your other post of seeing your rig from the outside for the first time...
It's pretty trippy I recently was in the same scenario being behind my chick as she was driving our rig as well ...so how many things did you notice that you need to fix or adjust. lol I found two that bothered me and thought damn I wonder if other people notice that, fix that right away.
Anybody have any experience with TC's univalve going loose?? I've looked at em and they seem in order to me, however this was wheel on as I haven't had a chance to jack it up and work on it yet
Uniball* Damn autocorrect
I was just there last weekend, and I'm going back next weekend lol. My profile pic is actually at cades cove back in January
Nice! We walked the first part of the loop this morning and saw turkeys, then drove it and the kids saw a bear. After that we took the Heintooga Road hoping to see some more wildlife but no luck. Still a beautiful ride! The park is beautiful and I'm jealous you're going back as we are going home now! Have fun next weekend!
Had to drill out my front diff plug. Stupid thing was stripped. I must have torqued it too much last time I tightened it.
Got it out with a lot of cussing and drilling. Then more cussing and used an extractor.
Then lost the magnets in the diff case. SO... flushed it twice and used another magnet to fish the magnet pieces out. ugh... what a pain...
but it is done.
After breaking one of my fox shocks last week ...I Got some new replacements delivered today I went with fox factory series 3"-5" inch lifts 26.15 ext and 16.06 coll with 10" inches of travel.
5th Gen Brake Upgrade
Replace front brakes. Pretty easy job if you have jack stands and some simple tools.
Centeric Calipers and Powerstop rotor and pad kit.
CENTRIC 141.44288
CENTRIC 141.44287
Power Stop K5873-36
14720492_10209986926205662_3913494239593573016_n_zpstc8y0sqe.jpg~original
73499c46-1c3f-465e-9f54-42106b38697f_zpsid6urihc.jpg~original
Bumper is coming off today, going to bake the headlights and try to clear out the inside of the lenses, new bumper will go on tomorrow
So back in the early spring, some time in March I believe I was cutoff by a white pathfinder on wet roads and I couldn't stop in time and clipped his rear bumper. My lightbar took the brunt of the hit, but also gave way and pushed back into the bumper causing a fair amount of damage to my 6 month old fresh painted oem bumper... I finally broke down and bought a new painted bumper and a new LED light bar to replace the damaged ones. Here's some pics of the damage, it was mostly cosmetic
IMG_20161015_130454743_zpsy4izgafj.jpg~original
The paint was creased all the way across the bumper
It was also flaking off in large chunks
IMG_20161015_130436334_zpsah2idy1j.jpg~original
IMG_20161015_130524851_zps3l2mrczi.jpg~original
The bolt for the LED bar broke out of the mount and I pushed it back into the bracket, it was good there for about 6 months.
IMG_20161015_130447577_zpsc7klfsen.jpg~original
The led bar was also cracked, but still works, even with moisture all over the inside
IMG_20161015_130516501_zpsilycwl5i.jpg~original
My retrofitted headlights also took a hit, well the passenger side, all but the long top bracket were completely snapped
IMG_20161015_130620982_zpspubpcfxk.jpg~original
IMG_20161015_130624150_zps9dmeya86.jpg~original
The headlight housing itself is also cracked, so I'm going to have to order a new set of housings before winter.... :tsk:
IMG_20161016_125002951_HDR_zpstrlgq853.jpg~original
I even found a dead moth in this one lol
IMG_20161016_125916537_zpscaib8dnd.jpg~original
So first thing I did after teardown was mock up the new light bar. I have a set of the brackets that MojaveMadMan made. I upgraded and bought a CREE C2 Series Flood/Spot to replace my C1 series less bright LED bar. Unfortunately this one is about an inch wider than the first one, so I had to bend the steel brackets out to make it fit.
IMG_20161015_160006150_zpsk6z3m6yc.jpg~original
But after some prying and bending I got it to fit nice and snug
IMG_20161015_154900116_zpsocxluwpo.jpg~original
IMG_20161015_155956265_zpsgqdw8k90.jpg~original
Upon discovering that I would need to buy new headlight housings, and that the spare set that I had also had broken mounts on the passenger light. I decided to throw my old lights back on for now and just mount the new bumper. My gf helped me get everything lined up since it's easier with 2 sets of hands..
IMG_20161016_172648281_zps8xgqx97b.jpg~original
Here you can see a better pic of the spot/flood combo. This bar is significantly brighter than the last one that I had, which I didn't even think was possible.
IMG_20161016_172657502_zpsdxmukrz7.jpg~original
And here she is all back together.
IMG_20161017_133214098_HDR_zpsshfrzdad.jpg~original
As part of the damage, the bumper brackets that the ends clip into were also damaged, so I have to order a new set of those, but it's on for now and it looks much better than before!
I'll be ordering the headlights and brackets soon and will have another update hopefully in a couple weeks.
Dropped mine off at the body shop today. Minor touch-up on the tiny bit of rust in the dings and getting some satin black paint laid down. Also getting that bumper bolted back on finally. Now I wait for the finished product.
Towed my brothers new camper and went camping. Airbags make all the difference in the world when towing. Trailer weighs 4000 lbs empty.
Awesome! Ya if you get there at the crack of dawn you can see lots of animals. We saw a pack of coyotes, some deer, and some bears last time. This weekend me and the gf are gonna hike the Abrams Falls trail. It really is awesome to live about an hour and a half away, it's a beautiful place. Thanks! :bigok:
delislerebecca
