What fuse relay box do you have?
What relay fuse box are you using/getting?
  • Bussman cooper
    Votes: 13 46.4%
  • Spod
    Votes: 7 25.0%
  • Other
    Votes: 8 28.6%
  • Total voters
    28
IronManKansas
I am looking at bussman cooper or spod. Are there other options? I want the wiring to look clean/ factory. Post your picture of where you mounted them :banana: thanks
I have the Tacoma version Spod in the box hoping to install over the next couple weeks. Assuming the garage is warm enough....
I see three votes for other and only one post. Help everyone one out let us know what works for you. List the pluses and minuses. Also :worthless show ever one where you mounted your fuse relay box under the hood. Let's learn from your knowledge( mistakes) :biggrin2:
Mine is still mostly a box full of parts...I only have the main power triggered relay setup and still designing the bussman.
i am planning to utilize the trail toys NSA box. I already have it and on this glorious 3 day weekend i plan to get it all wired up.
i had purchased a cooper bussman a few months ago. I never got it installed or wired up or anything and got a great deal from a local seller on the trail toys NSA box so i went that route. (my cooper bussman is for sale in the non-t4r items sub forum: Bodoke0326 Cooper Bussman Box somebody make me an offer :nerd: )
I hung out with Nathan from trail toys and he of course has one installed and it was so awesome to see him operate his winch remotely with it as well as turn on lights, his compressor for his locker, and any other items he had wired to it.
I vote the Bussman for simplicity. Here is mine sitting where it will live. All you need to do is move the doohickey with the heat-sink, which is in the picture just below the relay box. There are already holes here as well.
To simplify wiring, I am running a single run of semi-truck trailer wiring through the firewall (all of 3 feet). The trailer wire has 6 stranded wires in a nice insulated bundle. This will run to AOB switches.
[MENTION=107532]ADVnut[/MENTION],
What model Bussmann is that, sir?
Thanks [MENTION=123745]Sig_Fan_55[/MENTION] !
No problem, I'm also running one and they are very well built and fit in the spot pictured above perfect. The switch wires are the perfect length to reach all the switch pop outs right under the mirror and dimmer controls too. The only thing I have installed that was too much draw for the relay was my ARB compressor, they handle all of my lighting great.
Only draw back is now that you have so many relays and fused circuits you just want to buy more stuff to run off of it.
I am running low current/amperage devices and relays off of an FZ-1 box. Any combination of six switched circuits or unswitched circuits are available. Separate fuse for each. Using for radar, CB, light relays, etc. Works great in those situations. Mounted in center console.
FUZEBLOCKS.COM
Weeeee what is the purpose of the breaker if you have a fuse on all the circuits? Is it for your solar panel mod?
Short circuit protection in case too much current flows to the fuse box. Just because the circuits are fused doesn't mean it's entirely safe. Since the fuse box itself can only handle so much current, the breaker is there as added protection.
peacefulpiranha
