When will the Bilstein 6112 be released?
So I continue to search but I haven't seen an answer.
Has anyone gone from 5100 to the 6112's in a SR5? I want to know if the 6112 set up eliminates more of the brake dive and if it is worth it to upgrade again.
Well it's been a great day today....
Got stuff on the way as stated above and picked up these little goodies from my local Toy Dealer for my 6112's ....... :reddance:
Hey what did I miss regarding this upper assembly equipment from toyota? I'm looking at this very same kit once I'm ready.
If you decide not to reuse your old equipment.
this is what you will need if you combine oem & non oem items.
OEM: 4) 90948-01100 Shock Cushions, 2) 90948-02205 Lower Cushion Retainers, 2) 90948-A2003 Upper Cushion Retainers
Non OEM: 2) Monroe 907922 strut mount stud plate (comes with flange nuts) 1) Energy coil spring isolators 9.6104 (two in a pack) $125 or close for these items
ALL OEM:
90948A2003 (need 2)
9094802205 (need 2)
4860960100 (need 2)
9008017215 (need 6)
9094801100 (need 2)
I've prices for all OEM parts vary from $165 to $265.
I guess that is what I get for buying new top plates that are non oem. The top plates I ordered only came with the flange nuts. So, the washers, bushings and isolators had to be ordered separately. The diagram made me think there was only one bushing on top.
Yep,
As I posted, all the parts I listed OEM were all that was needed and included.
The lower bushing and isolator is on the OEM plate.
It seems to help with the nose dive more than the 5100. Valving is slightly more significant.
One more data point here...
6112 on the second to lowest setting up front. 5100 with stock springs in the back. No third row seating. 1-1.25" lift up front and a 3/4" normal rake from rear to front. Doesn't feel like a grand marquis anymore.
ALL OEM:
90948A2003 (need 2)
9094802205 (need 2)
4860960100 (need 2)
9008017215 (need 6)
9094801100 (need 2)
Hey, forgive me if this question seems obvious, new to customizing suspension. but what would be the reason for not reusing the existing parts?
By not reusing the old parts, you can put together your new suspension as a complete sub assembly before hand anad just do a quick coil over shock replacement for the front suspension. That way you have less down time and if you ever decide to swap back to stock (say you are selling your 4runner) you can quickly do the suspension swap and do an alignment.
So out of curiosity which spring is stiffer, the oem one or the ones that come with the 6112's. Are there specs somewhere?
Bought this 2015 Trail new about a month ago. Have done a few mods so far. Just installed Bilstein 6112 yesterday. Getting an alignment tomorrow. 3 setting from bottom. Waiting on my Bilstein 5160 and then I will just run rear stock springs with AirLift bags
Nice rig, dude. Looks like your running Nitto TG2's...what size if you don't mind?
Initial setup as of May 2015:
6112s on 2nd circlip, and 5160s with stock coils in rear
Updated setup as of December 2015:
6112s on 4th circlip, and 5160s with SAW 1.5 coils in the rear
See attached
*tires did not change over this time. I do have aftermarket Camburg MOOG BJ UCAs on the front, a souther style speed slimline hybrid bumper, spider Trax wheel spacers, and shrockworks sliders now as of the December picture which i did NOT have as of the May picture.
<Pics to come later> but as a teaser as youve seen here before it looks GOOD.
*tires did not change over this time. I do have aftermarket Camburg MOOG BJ UCAs on the front, a souther style speed slimline hybrid bumper, and shrockworks sliders now as of the December picture which i did NOT have as of the May picture.
Looking forward to seeing the updated setup!
Posting another reference. This has been posted on another thread, sorry if you have seen it before.
2013 4Runner Limited w/ 3rd row - 6112 on 3rd clip (2"); 5160s with SAW 1.5" coil in the rear. BFG 275/70/17 shoes on TE rims.
I wanted a little bit of the factory rake as I sometimes have my dirt bike hitched on the back. Lovin the feel so far on the road. Planning on testing offroad over the holiday break.
BEFORE
<a href="http://s860.photobucket.com/user/ncuthrell/media/IMG_2082_zps4yitneqo.jpg.html" target="_blank"><img src="http://i860.photobucket.com/albums/ab161/ncuthrell/IMG_2082_zps4yitneqo.jpg" border="0" alt=" photo IMG_2082_zps4yitneqo.jpg"/></a>
AFTER
<a href="http://s860.photobucket.com/user/ncuthrell/media/IMG_2092_zpsuysle6ed.jpg.html" target="_blank"><img src="http://i860.photobucket.com/albums/ab161/ncuthrell/IMG_2092_zpsuysle6ed.jpg" border="0" alt=" photo IMG_2092_zpsuysle6ed.jpg"/></a>
BEFORE
AFTER
How does this ride compared to the factory areas?
I'm thinking about this exact setup for our 2014 Limited and wondering how it compares - softer or firmer or not much difference?
Compared to xreas I would say the ride is more "plush". The vehicle seems to float over the highway but in a way where you feel it is well in control. The rebound of the springs is dampened very well by the valving in the shocks. I would say the combo is a great match. I am guessing SR5 owners will feel even more of a positive difference.
johnnya
