Where can I find a 3-pos-switch that could replace the dash-illumination wheel?
38vn38fa
there's a roller switch type thing on the dash, to the left of the steering wheel beside the backup sensor switch - I'd like to swap this out for one that just had three settings: high, medium, and low. Having a 3 position switch (or just two position for high/low) would make it easier to adjust the dash panel lights (instrument cluster, etc.) to high or low. Does anyone know where one could find a switch that would be easy to swap in?
The article http://www.toyota-4runner.org/5th-gen-t4rs/92013-antmans-thread-2.html#post811096 already makes it easy to see how one would access the panel in question.
EDIT: here are pictures of the "wheel switch" removed: http://imgur.com/7Mxe7fC,HYyDeO3,j28T07l,mjZ0tWX
Question restated is: is there a switch that could simply be swapped in?
"there's a roller switch type thing on the dash, to the left of the steering wheel beside the backup sensor switch...Does anyone know where one could find a switch that would be easy to swap in?"
Here's a great source of auto electrical supplies; one that "Antman" turned me on to, [email protected]. You can give them a shout,
Good Luck, rigtec
What about factory switches for other things - would any of them fit? (Where can I find a diagram of all the switches...)
I'm not a "TRUE" expert wrt 4Runner parts; just "dibble~n~dabbling" around. However, there are some members here who most certainly can direct you with this. If it were myself with a Mod related question, I'd call on..."Antman", "1Eng'R", or "Harper7" to be sure.
Hit 'em with a private msg; they'll be more than glad to help out! And let me know how you made out.
Best regards, rigtec
There are no "easy swap " switches for this. It would have to be a modified factory switch or an aftermarket switch. Frankly, it would be more work than it's worth.
Part of the dash dimming is controlled by CAN (computer) and I haven't figured that out completely (YET!) anyway.
Sorry Rig- "NOT IT!"
Thanks Ant,
your conclusion to the question was "right on point" (imho); the most positive, straight fwd direction available to you. Well done!
rigtec
I agree with with Ant.......way more work then it's worth and I like the function of the rheostat type switch so it would be a downgrade IMO.
Now if it was a TPMS warning light off/on switch we would have something worthwhile.I have work to do up under the dash soon and may try to figure that one out(pm'ing Antman of course).lol
I got the (not so subtle!) hint before Gary! Happy to help. Work has been suckin ass lately so I haven't had a lot of time to look into it...
Taking a potentiometer out, knowing that it is sending a variable signal to multiple outlets, and replacing it with a simple fixed voltage switch will be more difficult than replacing a simple switch with a potentiometer. Jeff and Gary know more about this than I do but I suspect there are a lot of 4-20ma pwm signals running around there.
