WhiteKnight Build - (Smallfry's rebuild)
Get a new one from a junkyard. Ive also heard of the temp sensing unit on the limiteds failing and causing problems.
That's one of the other things that I thinking. I did the test cycle to get the DTC code (21) which is the code of the sensor but from what I've read you can get the code as well without it being in the sun.
I wouldn't think that a bad sensor would cause the blower not to come on. Issue #1 I can live with but not having a working blower/fan isn't good.
Lift goodness.........Sonoran Steel 1.2A.
P1040205.jpg~original
Got the front lift completed but ran into an issue with the rear. While jacking it up to readjust the jackstands the jack crapped out which in turn caused my 4runner to shift to the left and putting the axle on the floor :eek:. Spent about 45 minutes slowly lifting both the sides up with my spare jack to get the jackstands back under it.
Hopefully, by Monday night it will be back on 4-wheels.
Tire wise I think I'm going to give the Cooper Discover ATP's a go and see how they do. :)
Hope you get it buttoned up soon man.....sucks that the jack crapped out like that... but lucky you weren't under the truck when it happened!
After 3 nights working off and on the lift is done thanks to some help from a local TTORA member - Russell.
Crappie cell phone photo
photo2.jpg~original
Another item stratched off the list: rear diff. breather extenesion
This weekend two more should be taken off the list.
Well, after a long Saturday morning my 4runner is armored up a little more and sitting on some new tires.
P1040368.jpg~original
P1040369.jpg~original
Gotta thank Rockware (they have a nice buggie they used at the KOH) in Colorado Springs for welding on the sliders this morning.
Next up will be to get a tune-up and find out where the metal on metal sound is now coming from when I turn (I'm think it's getting from the drivers side front wheel).
Finally, got around to installing my CB today minus the antenna.
CB control box is the gray box to the left
P1040396.jpg~original
The CB
P1040398.jpg~original
Clearance, I'm going to pick up a 90* bend to see that helps some. In hind sight I probable should've put it higher up or on the passenger side but I'm happy with it overall.
P1040397.jpg~original
