whos gonna throw one of these in their 5th gen?
Verso 2.28 x 4.70 Dual Gear-Drive Transfer Case
Dual RF1A top-shift gear-drive transfer case that features a 4.70 low range gear set built with our very own Verso™ Transfer Case Adapter. The Verso™ T-Case Adapter allows for the use of a gear-driven t-case with a left hand drop front axle. The Verso™ T-Case Adapter is machined out of aircraft-grade 6061-T6 aluminum for increased strength and durability. The Verso™ T-Case Adapter has almost a quarter inch of added material around the idler gear bearing for additional strength.
Each case is fully rebuilt and inspected. Triple drilled flanges are installed on both front and rear output. This Verso™ 2.28 x 4.70 Dual Transfer Case is built with a 23-spline input gear. Can be installed as a replacement to your stock chain driven transfer case. To go even further, we will include a Mechanical-to-Electrical Speedometer Adapter and your choice of shifters with this kit at no additional cost! The shifters will be provided uninstalled. Available with an adapter for 3.0L, Tacoma 2.7L, 3.4L, and 4.0L applications (transmission adapters are provided uninstalled).
