Modifications, Write-Ups, Quick Links, and FAQ's
Status
Not open for further replies.
Jesse1983
5th Gen Moderator
The purpose of this thread is to consolidate 5th gen specific modification writeups in an easy to find place.
Please create a new thread for your mod. Once that thread is created, PM me and I'll add it's link here. That way all the conversations having to do with the mod stay in that thread, and this one just contains links.
Thanks.
Engine Performance Mods With Attached Dyno Documentation
The Build Thread of my Rocky !!! - Toyota 4Runner Forum - Largest 4Runner Forum
FAQ's
Changing Tire Size or Wheels? Read this first! - Toyota 4Runner Forum - Largest 4Runner Forum by @wfo9
5th Gen Tire Fitment Guide by [MENTION=66316]1engineer[/MENTION]
5th Gen 4Runner Lift Buyers Guide by [MENTION=45399]thebwlife[/MENTION]
Strange Noise/Evap
http://www.toyota-4runner.org/5th-gen-t4rs/215622-diy-maintenance-quick-reference.html by [MENTION=135484]renau001[/MENTION]
5th Gen Maint. Doc. Reference by [MENTION=49863]WhiskeyCop[/MENTION]
Light Racing UCA problems
Should I get a Jeep or a 4Runner
http://www.toyota-4runner.org/5th-gen-t4rs/214398-consolidated-lighting-info-thread.html
Quick Links:
http://www.toyota-4runner.org/5th-gen-t4rs/225872-did-you-break-4wd.html
List of Customizations That The Dealer Can Program for 2010 T4R by [MENTION=47619]doodman[/MENTION]
TIS FSM for 2010 4Runner by @Nashman
Parts Manual by [MENTION=8206]harper7[/MENTION]
Reset Maint Required by [MENTION=8206]harper7[/MENTION]
Companies that make modifications for 5th gen by [MENTION=68981]jam23r1[/MENTION]
Consolidated Slider Info Thread by [MENTION=115953]HerT4R[/MENTION]
Consolidated Bumper Info Thread by [MENTION=60221]bryancostanich[/MENTION]
Mods / Write-Ups
Exterior Mods:
http://www.toyota-4runner.org/5th-gen-t4rs/235450-5th-gen-power-folding-mirrors-how.html
http://www.toyota-4runner.org/5th-g...to-tutorial-so-easy-6-yr-old-girl-can-do.html
New Fiamm Horn Install by [MENTION=47340]Titanpat57[/MENTION]
Painting Plastic Auto Parts the Right Way by [MENTION=8206]harper7[/MENTION]
How To Install Roof Rack Crossbars by [MENTION=5457]x67934[/MENTION]
DIY: Roof Rack Delete by [MENTION=59081]W8kbrder[/MENTION]
Debadging by [MENTION=8206]harper7[/MENTION]
Rear Diff Breather by [MENTION=50366]jgedmond[/MENTION]
New Location for Rear Diff Breather Ext. by [MENTION=1913]hoeftm2002[/MENTION]
Blacking Out the Runner's Chrome by [MENTION=47619]doodman[/MENTION]
Yaw Rate and Acceleration Sensor Zero Point Calibration by [MENTION=51374]iDRiVaT4R[/MENTION]
CB Antenna mounted in the OEM XM shark Fin location by [MENTION=51374]iDRiVaT4R[/MENTION]
TE Parts Needed to Convert SR5/Limited Exterior by [MENTION=8206]harper7[/MENTION]
Rocky Road Slider Step Mod by [MENTION=47340]Titanpat57[/MENTION]
Satoshi Grill Mod by [MENTION=49537]4ShoreRunner[/MENTION]
Engine compartment light mod by [MENTION=54940]Snooperstyle[/MENTION]
How-To-Installation-Guide (Grillcraft Upper/Lower Grill) by [MENTION=57963]TOYSTRY[/MENTION]
TRD CAI Install by [MENTION=57963]TOYSTRY[/MENTION]
Independent Fog-Light Mod- using the factory switch by [MENTION=65614]Antman[/MENTION]
Toytec Top Plate Spacer Lift [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
Door Panel Removal by [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
Airlift 1000 airbag install by [MENTION=65614]Antman[/MENTION]
DIY Airbox mod by [MENTION=65614]Antman[/MENTION]
Moving front fender liner to accommodate larger tires by [MENTION=8206]harper7[/MENTION]
Add cup holders to rear bumper by [MENTION=65614]Antman[/MENTION]
Always on DRL's (Daytime Running Lights) by [MENTION=65614]Antman[/MENTION]
5th Gen HID / Projector retrofit installation by [MENTION=51186]philsey[/MENTION]
How to take headlights apart by [MENTION=58658]deekoi[/MENTION]
N-Fab side step install- Rocker panel trimmed: HOW-TO by [MENTION=65614]Antman[/MENTION]
Oil Change 5th Gen: How To by [MENTION=65614]Antman[/MENTION]
Dual Batteries on the Cheap by [MENTION=47340]Titanpat57[/MENTION]
Sears Platinum 31M Battery Upgrade by [MENTION=47340]Titanpat57[/MENTION]
TE - Rigid Install in the Rear Bumper by [MENTION=47340]Titanpat57[/MENTION]
TE Headlights, Black Headlight Mod by [MENTION=48772]Jesse1983[/MENTION]
LED LIGHT BAR INSTALL on a 2014 T4R by [MENTION=103267]Saker[/MENTION]
How to Replace Side Mirror/Puddle Lights by [MENTION=66390]ROBSCOOL[/MENTION]
DRL Disable but keep Auto Headlights by [MENTION=4160]KDCane[/MENTION]
Interior Mods:
http://www.toyota-4runner.org/5th-g...grip-handles-install-2014-toyota-4runner.html
Mods - ATRAC & Locking rear dif in other than 4L by [MENTION=31049]LWN[/MENTION]
How to use a usb hard drive for music by [MENTION=48175]poolzer[/MENTION]
Seat Heater Install by [MENTION=63224]Mijfwb23[/MENTION]
Cargo area LED light mod by [MENTION=54940]Snooperstyle[/MENTION]
Removing Stock Head Unit by [MENTION=70510]darkdane[/MENTION]
Switch to Activate Backup Camera by [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
Rearview camera mod WITH NAV by [MENTION=65614]Antman[/MENTION]
How to Make Interior LEDs [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
Interior Door Handle LEDs by [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
Cupholder LEDs by [MENTION=65614]Antman[/MENTION] and [MENTION=48991]sp8ball[/MENTION]
12V Outlet Always On by [MENTION=65614]Antman[/MENTION]
Antman storage mod by [MENTION=65614]Antman[/MENTION]
Subwoofer Install by [MENTION=65614]Antman[/MENTION]
Line-X Cargo Mod by [MENTION=57963]TOYSTRY[/MENTION]
Flush Mount Scanguage by [MENTION=65614]Antman[/MENTION]
Simple Drawer System by [MENTION=47340]Titanpat57[/MENTION]
Scan tool on the Cheap by [MENTION=47340]Titanpat57[/MENTION]
Drivers Side "A" Pillar Grip Handle by [MENTION=103267]Saker[/MENTION]
Status
