Bfaulken's build thread "Duke"
these better fix my baby...
blown diffs + exams/projects + ZERO free time = a very stressful few weeks.
So I blew both diffs last weekend, crazy. Did some searching and found these for cheap. I wish I had the budget to regear or at least add a locker right now, but when you blow both diffs (4.10 gears), then find "3rd Gen toyota 4runner front and rear diffs 4.10 gears" for $350, I gotta believe it was a gift from God after being quoted $2500+ by a shop to do the work. Now I just gotta find a driveway to work in...can't stand living in this apartment.
2012-12-02_00-29-41_826-1.jpg~original
Cool build man, glad to see you got a good deal on those diffs.
Did you get a shop to confirm that was the issue?
Yep, I wasn't sure if it was the diffs, t-case or tranny at first. It sounded like a machine gun going off, among other noises. Took it to a shop (Best Western Transmission gets decent reviews for anyone questioning the shop's credibility) and they said the front is completely destroyed, and the back isn't quite as bad, but still blown. They said that everything else was fine, so I'm hoping they're right.
Sorry to hear man, one of my worst nightmares but I guess that **** happens.
What's next up on your build after you sort out the issue?
James
James
First up is saving cash to put into a "just-in-case" fund.
Then, mainly just small stuff, i.e. I have a sub & amp from my previous truck, so I'll put those in around the same time the diffs get installed, then probably a CB radio. Maybe a storage system in back for the sub,amp and misc. tools? not sure yet.
I'll also probably start searching for a good deal on steel plate since I found a friend willing to teach me to weld... :biggrin2:
sub & amp
Spent a few hours and got my sub and amp installed, sounds fantastic! Its a Kenwood 12" with a Kenwood Mono amp. I had them in my truck before the T4R, so why not put em back to use? I'm hoping to build a storage box this summer with these built in. :rockon:
2012-12-13_16-48-27_748_zps788a83cc-1_zpsf0abaab6.jpg~original
Diff Carnage/Replacements
I have 2 weeks to kill before school starts back up, so I decided to start on replacing my diffs today. Got under it to find that 2 of the bolts connecting my drive shaft are missing...Apparently I didn't tighten them enough when I had it out last :doh: Looks like I'm off to the dealer to pick some up. Moved on to the rear diff, and got the new one in. Took maybe 5 hours from taking wheels off to getting the wheels back on with everything connected but the drive shaft.
If I had a shop with a lift vs. laying on my back the entire time (wrestling with the diffs, bolts, etc.), it probably would've shaved a good hour or 2 off. Not to mention it was about 35 degrees all day.
started with these:
diffs_zpse70cd367.jpg~original
Took the old rear diff out to find about 8 teeth in shards from two places:
2013-01-10_17-18-48_448_zps87248a0f.jpg~original
2013-01-10_17-31-55_635_zps6aa98e8a.jpg~original
2013-01-10_17-32-04_690_zps36f45731.jpg~original
I'll probably work on the front diff this weekend, then fill them up, try to jump start my dead battery, and see if I have a working 4Runner!
yeah, I can't wait to pull the front apart and see what it looks like, supposedly its even worse! The next few days should be interesting, and cold...
It lives!
Well it's been way too long, but I finally got the front fixed! The CV's did NOT want to come out of the old diff, so I took em apart at the joints and added new grease and clamps, which pretty much showed me what to do when I decide to reboot. Then I bled the brakes (Speedbleeders are wonderful). Overall, swapping diffs is a relatively simple job, just super time-consuming and requires a lot of tools & oil that are handy to have anyway. Plus, it helps with general knowledge for future maintenance.
This part seems crazy: replacement drain bolt vs. the one that was in my blown diff. Apparently whatever teeth are floating around got to it.
2013-01-17_13-11-17_489_zps0af27118.jpg~original
Old out, new about to go in:
2013-01-31_15-03-31_76_zps29af0f92.jpg~original
No diff, CV joints all naked & whatnot:
2013-01-31_15-03-40_157_zpsb5d37dcf.jpg~original
I'll post pics of the old diff ring when I open it up, probably tomorrow...
Whoa...
Opened up the old front diff today. Thought I'd share some pics :hatsoff:
This is one of those "just wrap it in duct tape!" situations right?? :tinfoil3:
2013-02-03_13-15-30_523_zps7e8b03a1.jpg~original
2013-02-03_13-16-21_703_zps9bbf43e4.jpg~original
2013-02-03_13-16-34_543_zps527d608f.jpg~original
Not much of an update but a few months ago [MENTION=81720]TMAC110[/MENTION] (my roommate) snapped his rear swaybar and found another one with endlinks at the junkyard. I snagged his old ones and finally got around to swapping them into mine. They look to be about 2 inches longer than mine were.
I know the boots aren't great but they're better than my old ones anyway.
New project
So I was browsing Craigslist yesterday and something caught my eye, so I called the guy up and picked this up today! E-Locker!!!
It came off a '98 4Runner, and the guy swears its a 4.10 ratio, so no need to regear, although I'll double-check before proceeding. I'll have the 3rd rebuilt for safe measure, then I'll re-do the axle seals and inspect the wheel bearings, sand/paint everything to get rid of the surface rust, and swap this one under the rig! Just gotta figure out the wiring part.
:lock1:
Great find! Yeah that would be pretty bad if you put it on only to find out it's not 4.10! I'm glad to see there is someone else out there on a college budget! Stuff doesn't come as fast, but when it does it makes it all the more worthwhile.
Stuff definitely doesn't come fast, but make sure to have some savings whenever possible in case you find a deal! OR if you happen to grenade both diffs and have to pay to replace them. Scroll up to find out how I know...
I just browsed your build thread, looks like you have a great rig to start on!
Craigslist is my friend. Lol yeah I read about it man! That really sucks! But hey it all worked out in the end. And thanks! I'm really looking forward to this summer! Hopefully it will yield large amounts of lift :)
seltzernator
