Brilliant's Mod Thread
Brilliant
Photobucket and Flikr policy changes have broken many links. I have moved items to Google photos and I am slowly rebuilding this thread.
Since I've rebuilt this thread several times, somethings are out of order.
After years of looking at 3rd gens, I finally bought one. A Desert Dune 99 limited with the locker. This is my first Toyota, and first 4wd. I've wanted one for years so I am pretty excited to own it. I lasted 1 day before I started modifying it. I'll be using this mostly for my outdoor activities, and won't be on anything more than bad forest roads. So on road, off pavement type stuff.
As it sits now (@ Oregon Dunes).
AIL4fc-RW3T174xfTiZNMVaEJ35ERez9hod_jnCYuaMgteLZJgX-Dkmw-wAV-m7LgnAg8Rd7RknXNYVdiYGecxb8z-OU-3PxyS8r5dR4sRKfJajuhMDjR8w5G0CYElzg2z1YVilQ-dBEd1rv5JcDkpggOhiPGw=w1247-h857-s-no
OE
1999 Limited Desert Dune w/ rear elocker
MODIFICATIONS
Drive Train
Exterior:
Interior:
Lighting:
Electrical/Instrumentation
Comms
Suspension
Performance:
Wheels/Tires:
Armor/Recovery
Misc
Misc Camping Things
Stuff I need to install/finish installing
  • Surf tire carrier
  • Surf fender lights
Misc Shots of my 4runner
Drive through tree
AIL4fc9z1Op1HpDRHxtCCE1bpd_8aLIDfN6InIFzj664lSCbqiqeDKuOFpXViPl4JgVq_XrmtfsJb2zQ2UuoGKt_zqWfN5lHerwTM5q5H1mzc_VJyUD-efoAFDqoDZKwoQeCTZHOc_PsbJPY3rTOUzb54sgvbg=w1289-h857-s-no
WABDR
AIL4fc9sRauJbWv06tpaxQLWhtVw291jdTNoXh60KtUmXdclKai6G_SgcOJnk_MdM6mfbezekJbgVuqIouv55ZyK6DtgP23q-Yz1hCXMw4DQkj2c8bIpnF1AS8gc93olPlZWg9Njm6aLcJilRdEJfWkHk_sjuw=w1289-h857-s-no
btw if you are going to spend more than 100 bucks on a used bumper i would suggest you to get a offroad tube bumper, they offer way more protection and functionality, thats only if you are a wheeler
Nice job with the dash!
(Also props for the humble choice in a user name)
Mileage?
BTW, I clicked to see picks of your BMW but there are no pics.
:bat:
haha well I was just trying to be funny.
your BMW sounds pretty awesome to compliment the 4Runner. I used to have a 325is and have always wanted an M3.
good luck with the 4Runner build.
I'm intrigued by your choice of aux lighting. I'd have a defiant light bar or baja style tube bumper with 3 Hella 700FF's if I had the cash laying around too, and I was considering the Hella 450's also in addition to my pair of Hella 700's. Where exactly are you planning on mounting the Hella 450's?
Have you seen if those light switches are very bright? That would be my one gripe about the OEM fog switch...
Nice build thread so far, and I look forward to seeing it progress :hungry:
:p
bubble? You mean what bulb is the tach illumination bulb? If you take out the cluster its pretty straightforward. Pull out the cluster and look at the basckside. The tach light on sits about mid cluster. Its all by itself, cant be missed. They are T6.5 wedges aka Type 24. I used the lense covered superstars. 3 LED ones were too loose to fit.
No in the pictures it looks like there is a fairly large bubble on the guage face of your tach. On the left side of the needle.
Mod: Replace fat lip bumper with 96-98 bumper
Steps:
  • 98 bumper, valance, and 98 bumper supports, and bumper flares
  • RR 99 bumper with 98 bumper with 98 supports
You cannot reuse the fatlip valance with the 96-98 bumper, the bumper metal is thinner than the 96-98 bumper
Installed
AIL4fc-pPb2iRVYRc9Xlr1wAIqWh9VkGMhZlPIKmzbXftm58eRErEiwJDA2fpIMhDrjvRON116A9Xog0jLZ0a80ZsdNbkXK3TNea3EWQ78xZfzZdkQf-MpNV6zNF0TyVoF7YmSbYIVHhPFHydARJlPnzqythJg=w1079-h857-s-no
I did some misc maintenance items today, all gearboxes with Castrol synthetic, fuel filter, and lubing the drive shaft.
I also installed the el grande horns. The horns go in super easy, clip the drivers side connector off the drivers side, find the one hot wire (hot when horn depressed), and make a Y to both horns. Note the other wire on the drivers side runs over to the other horn so you could use this too. The horns are grounded by the back mounting bracket, similar to the OEM horns. I didn't use the relay or any of that mess.
No more moped horn!
AIL4fc-yar0AgXW8ni4gqsedv38G6qgohLsfrm-ea6USibezPMPmoOJQ4k8yv4LbsVwtUKdAYkKji9ROg4lJ4k_wSkzul8P_JDqEHxl2hldo9k_IgDGp8AURWzJIafJ2Z8_3IFqK7JcA-P7MgraAj3rG6hvQZw=w642-h857-s-no
Those Micro de's turned out awesome..it's very gratifying to know that some of the mods I do actually inspire other members and apply it to their rigs.
Thanks, and a well built 4runner as well.
Objective: Install Hella Micro DE lights in valance, replicate look from [MENTION=46329]blcktpgsr[/MENTION]
Process:
  • Take off front 96-98 bumper
  • Measure diameter of lights, obtain holesaw of desired diameter
  • Cut paper template of the diameter of lights, make legs to position left right top bottom
  • Lay paper template on bumper, mark center
  • Flip template over, repeat on other side
  • Drill hole, debur with razor
  • Drill slotted hole in bumper support for adjustability
  • Build a washer stack / spacer (JB weld a flat bar and use spacers)
  • Notch bumper brackets to clear lights
Paper template
AIL4fc84x4X3tY_6ITELeWqTaoCGsvcYZO9CJVCK2Chahe-c7-4J6daxtGzwt72aQo1ySX-yh1fzqO9-dAa82XySOhPSHNqrqnNsmr-cVT9WAhwV5h5wwgKNzZfsSPcyxe6GXp-h2zKeVo-2LuduybRsmnh8AA=w642-h857-s-no
Light positioned with washer stack
AIL4fc-0Dg20diiLkWW1qn9CB1R655_rFJdJNf6ObVHtfXlbTFK8XADHrhKqnNcMoggXk7s18ARE2WLOLqeAKN-fq78K3-zXesj1ljGxEMzbzu-eyLurJm_m9yfjSV5nj0ER_XJ4mD3n9P9_f6oVf35Eut8Kpg=w642-h857-s-no
Lights installed
AIL4fc8kfNMtrzXoTJr-t9uen6dAjtUveyPua3Fc7wMLVyPsstAUoLLC1R8gk60pVVTr7QaLnecfumzq-exTwSRSCmmqMo9Tqa2yW4vofcErArV5dS1ee1EY15qD5lmeKoDzsZuEtEhppD3kxqWU8t-abNXIQQ=w1142-h857-s-no
Those Micro de's turned out awesome. It's very gratifying to know that some of the mods I do actually inspire other members and apply it to their rigs.
yea, man. Your idea was exactly what I was looking for.
:guitar3::guitar3::guitar3:I think it was actually Performance Products who sported that lower valance lighting design for the 96-98 model, but they've been paced out and nowhere to be found....so I kinda mimicked the idea.
Looks good man! Did you fab up pods for your lower valance lights?? Mine looks the same as yours from far, but I added pods to make it look more OEM. I love the fact that you used OEM switches.....that's one thing I didn't do....still running the chromed toggle switch on the dash..... lol!
These have since been removed but its useful for OE switch info for a set of lights
Mod Purpose: Add additional lights for driving in the dark, something cheap that works
Steps:
Hella 500FF and HID kit
Factory switches, plugs, and inserts
Wire up the lights to a relay, use a terminal crimper for inserts
Use heat gun to dome the Hella 500FF to fit the bulbs
Find existing holes in underside of bumper
Cut out valance to enable hellas to sit flat/recessed
Crimper I use for all my Toyota and BMW harness repair and Deutsch terminals
AIL4fc9J8LD0RXsb4IoP7_sC624mwi-4GzhOC3US-GE1XGixHcLpCch6RKQWkGhkylwp9OhoUGvaSj2Q9wzfKXU1AJsPFcxFF7iR3DAgJeMp27N39yTwBKSdJdoO_ziAku9eKtC2tQ3l9lRHllfTS1H3Q8WPVQ=w1142-h857-s-no
Switch diagram
AIL4fc933V9h5PqOAOLyJCg_8tPI-Tcyj8DjzxAOJRgMtCO2oeYh9KnvJd2sIEJvWBhwCKlioY2-bB3zI5QEE-iJKXyKDm9WJgtaZUlw1PaVIl6GtKdiNLioQ1oO8glh9Rmc-QvEqcyC1KToDT8OD0w2DJTjNA=w320-h154-s-no
OEM plug and harness
AIL4fc__kNt1rCpRkSi5kmF2MrJqjavghCT5gKyZqlUD9fKJlZIZX-XBV6mQVuzqCAKvgBB2t2w0itFxC_RZUR0n9UjNRADd3nMgtghF-JTNb9WtagzTyGD557BrSHxOppQHeFR3ap10OdbESHHY3_2UmlYvhg=w1142-h857-s-no
OEM style Switch
AIL4fc-PfrsfCn67MQ_zTrQtCkEyvdPHWsTnAaHD9x0SvOhF4aNZ7StHyud_gI5FOP-zKweAV1Hl2NbDb-VJ9Gza-rjoxIJGM7ucrgyAPv9KHoOslqbyEFy7KIh9MQ35l8SwtoVum8pKk3mmsqFlEBlp53D_AA=w797-h682-s-no
Installed
AIL4fc8U9ac3VErTu8LhoMaNC9_xbGnpK0cgEhir_23OmAbnuAB5BwWLSUSdK89ewT0KP63SuSJz840MwOcPmSi-4cReWG98ellpcan0qGZWBdDqOiYrKq9Iy_2rfA_QfS1Sou6MfCurURDxvUGkde1EvBBF3g=w1142-h857-s-no
thanks - I didnt do the pods like you did on the 500s but I have seen your setup before and I am considering it. =} I took out the minimum material so the light backshell is right up against the valance. I just kind threw them on there and called it good.
Objective: Install OBD scanner gauge, keep it OEM+
Process:
Pick up Aeroforce interceptor gauge
Measure diameter of housing, but holesaw of same diameter
Using a holesaw, cut out center console around shifter
AIL4fc_T5_zOI4pacUH-9mJIFtx9fGkcBczfpU6BqmZdU3sm-smETc20fOYWoOvO_VW6QAAzgpcTwc5OwdWwWN2A0M6D3ePTv81fBdSyT_AbFaQgTYKUo0oRPhiFSa6nFxTgRaOg-771zdXPWf3nyQx4zAsV0A=w1142-h857-s-no
AIL4fc_oDxUOwqVQ4_64Fz8uovOYMZEUi11YiIXgb5l9aT-UTAxvukrIew2W94lsIAVJ6grE5q95-uFx1mQ-aCTQh94IxZJD_aAhKvyOnn8DuMrNGYTd_Qc13yFjj14rTo5KxIwQdXe7HWws7KiJ7w0dpVEaHA=w642-h857-s-no
The analog input is shown there too. You get a pigtail (not shown) with the gauge, that connects to a PLX boost sensor
Pretty cool man. Can you post some more pics of the interceptor mounted.
Thanks.
CeasarNPrawns
