'Hi I am looking to get a little extra power out of my runner... I was thinking of doing a Cold air intake and maybe a chip if i could find a good one.'
"magic snake oil elixir that's only found in the far, far east, from a "female" King cobra, in a dark cave during a lunar eclipse, but only on the Chinese new year...hwell: Okay, a little creative license taken here "OF COURSE", but you get the point!
rigtec
This stuff WORKS. Okay! It's tried and true. I have countless charts, tables, graphs, pie charts, tables, comparisons, maps, more charts, even more comparisons, and did I mention tables?
I can attest to this stuff. My dashboard tells me I get a 500 miles fuel range and then when I get to half a tank it drops back to 90 miles to empty. But the point is the stuff works for the first half tank of gas!
:lmao:
Good one!:yo:... and I do stand corrected! :moping:
"Hahaha, I couldn't help it. I know you'd appreciate the over-the-top argument and humor, recent posts in other threads in mind..."
"To the OP... good luck on your search. I think a CAI will prove to be a waste of money..."
..."Not that there's anything wrong with that!" Jerry Seinfeld
"...and I've tried searching for more over-the-top modifications (supercharger) but to no avail.
Really... I always thought that a supercharger was a factory option on the 4R? Well as they say... "you live and learn!" Thanks for the 'heads-up'!
Not cheap but Bully Dog cracked the Toyota programming code. They are the only ones to my knowledge of reprogramming the stock ecu.
Nah that whining you hear is the OEM factory installed kittens.
The first place I checked was TRD's website... :/
Then I tried google. The search returned... Haha. haha. this product does not exist. silly man.:croc:
You can order it and have it installed by the factory on vehicles that are applicable, see the rest of the post.
The issue is that Toyota does make a TRD Supercharger kit for the 1GR-FE 4.0L V6, but it is the SINGLE VVTi unit. Their kit is designed for the Tacoma's Carry-Over engine and actually has its own Factory Re-Flash (as opposed to say the 2UZ-FE 4.7L TRD Supercharger kit where the end-user had to get a stand alone ECU for it.)
There were statements last year I believe by Toyota at SEMA that there would be a TRD Supercharger kit for the FJ Cruiser with a Factory Re-Flash (which is the DUAL VVTi 1GR-FE 4.0L V6 that the 5th Gen 4Runners also share), but that will most likely not translate to the 5th Gen 4Runners. Not to mention that there would be no factory support more than likely since you'd be installing it on an "unapproved" vehicle with a Re-Flash not designed for it.
I would have been happy with around 315hp and a reasonable torque range.
This is true! As [MENTION=66389]BlackWorksInc[/MENTION] has brought to our attention, our 4Runners already have a "cold air intake" which draws cool air in from beneath the right front fenderwell. To purchase one with "TRD" and a toyota (longhorn) logo on it would look pretty cool (imho), but that's where it ends... purely aesthetic
couldn't agree more - hopefully it will be the "main thing" they address with the 6th gens
My question is then this - how do they make the claims on the gains with a CAI if the 4R already comes with one? Is the flow improved in a new CAI (less restrictive)? Or is it a combination of replacing the full plumbing/breathing system (intake, headers, cats, muffler, etc.)? I guess I'm just trying to figure out if their claims are false - how can they continue to advertise these supposed gains?
Which is heat soak in the area of the sensor and ductwork. Going to get the same result with a "cold air intake"I monitored my intake air temp today and had about 10-16 degrees above ambient in town and between 6-8 hwy so nothing too crazy. So even if you can drop this a bit it won't make any real difference.
The claims are just as they're posted on any webpage regarding the modifications - dyno tests b&a, air volume increases b&a, air temp, etc.What precisely is their claim?
Even replacing all that you listed above will not increase hp. Sorry. Now if you included "throttle body" and "ecu reflash" then you would have something but on this vehicle making it breathe and exhaust easier will have extremely limited effects.
Supercharger + ECU reflash
Turbocharger + ECU reflash
Larger throttle body + ECU reflash + Exhaust mods
Those are the only ways. Anything else is just for show.
Now if you can find a spot at sea level to live that has cold temperatures and high barometric pressures and low humidity then you can increase HP for free.
