28's build thread
Clean 4Runner. I love a white vehicle. Does anyone else think that this is the height they should have come with stock? Damn that looks nice.
IMG_20130624_150854_336.jpg~original
Thanks and I agree. This is just the right height for me personally.. Just waiting to wear out these tires to go to a more agressive tread down the road :hatsoff:
Figured Id do an update...
Did ftrasfer case and diffs..
20140116_184127.jpg~original
Changed front wheel bearings with OEM..
20140227_183813.jpg~original
20140227_183759.jpg~original
Upgraded my rod holder with a Yakima ski rack mounted on my walmart rod.. Also got my green Slime compressor mounted in back..
20140404_174520.jpg~original
With my Smittybilt Rack mounted.. Don't use it all the time since I haul my tarp tube most of the time..
20140118_080422.jpg~original
decals3.png~original
Which Slime compressor did you mount? I imagine running power to it was simple as well?
Im not for certain since I've had it for like almost 3 or 4 years but it cost me like 60 bucks at wallyworld. Have it simply hooked up to my 12V outlet. I mainly use it to air up my quads and have used it only a few times for my truck. But it's held up fine and been a pleasant surprise..
Real nice! Did those hubs fight you any coming off?
My drivers side did a little but eventually came off no problems. Was easier than expected actually.
Can you post more info on the under carriage lighting? Truck looks amazing!!
Have to check but I want to say 3 1W LEDs on each side and the rears are 25W I think. All wired to positive with fuse and relay in switch under dash.. The LEDs actually cost me more than the rears but came in a solid machined aluminum casting. Simply ran my wires along the frame rails and zip tied everything then shrink wrapped all the connections.
Thanks for the compliments guys.. :)
My own homemade load bars. Made them to be able to use for various loads but mainly for my kayak and roof top tent.. Also retouched my grill..
IMAG0028.jpg~original
And got my Duratracs on and removed my mud flaps... 255/75/17...
IMAG0024_4.jpg~original
IMAG0069.jpg~original
Installed my reverse lights straight to reverse light wire on hitch harness..
Used 2 Eagle Eye 10W LEDs
hey I live in Amarillo! Nice to see other modded 4runners in the area.
Also saw your thread about the scoobs. About a year ago had a 02 WRX with an STI swap, forester suspension, and general grabbers haha.
That's cool.. I liked the Scooby but just hated it for long trips.. You got pics of your ride up anywhere?
erinobr2000
