nismoxr34
Hello Everyone,
Just wondering if one of you knew the size of the o-rings for the AC system. While trying to get my new UCAs in, i had to move some of the AC line out, I accidentally removed not the bracket, but the line with an oring and the even with just a slight leak and retighten, the oring is busted and needs replacement. I wanted to see if anyone knew the size, and then I can just drain and fill after.
It is pretty much next to the refill cap like pointed out here:
And it should be one of these o-rings. I will probably need to drain before I 100% pull out that o-ring but if no one knows, I guess thats the route I will go.
Kelvin
Kelvin
