On Thursday, [MENTION=139465]Ohio Hawk[/MENTION] [MENTION=149963]JMFP![/MENTION] and I got started on installing our three racks. Later, two other local 4Runner owners joined us for conversation and to help out. It was a fun day.
We took probably too long on the first install, making sure everything was lined up, measured twice, etc. By the second rack, we had it figured out and installed it (mine) in about half the time.
Hint: Don't worry too much about getting the rack lined up left/right before drilling the front hole. Just use the temporarily attached rack to locate the hole front to back. Then drill in the center of the trim groove. When doing the final install, center left/right at the back and tighten only the back two bolts. Then center left/right at the front. Then make sure the side rails are straight (not bowed in or out) and tighten the remainder of the bolts.
Anyway, we didn't have time to start the third rack, so we used the rest of the time to install my Gobi ladder and struts, as well as the two fairings and the remainder of the cross bars.
Of note: The first rack was on a 2010, and the rear-most crossbar cleared the shark fin antenna just fine. On my 2016, even using the rear single hole and rear slot, it interfered with the shark fin by a good amount. I temporarily put the rear-most crossbar in vertically using the last hole, and will order a single-wide crossbar to use back there.
Photos:
On Friday, I installed my OPT7 32" lighter and the Road Shower 2.
And on Saturday, I installed the ARB 2500 Awning. I originally intended to mount it from the side rail using spacers. But the sag in the awning bag would rub on the vehicle, and it looked like it might occasionally interfere with the doors.
So I used a pair of Rhino-Rack Foxing Awning mounts that I had previously used on my Outback (and drilled to the correct 1.88" ARB spacing.) These work great! I mounted them to the Prinsu rack using the rack's supplied mounting rings. I'll eventually get appropriate fasteners to use, so that someone can't walk off with my awning using just a screwdriver or a sturdy stick.
I temporarily placed my MaxTrax where I think I'll mount them and took a few more photos. I really like the rack! It is *much* quieter than my Thule crossbars with Yakima LoadWarrior basket, and offers a lot of space and configuration options. I highly recommend it!
