eddie333
I have done a little more research into this problem. I am still having the issue where my camera either:
1. works fine
2. gray screen
3. colors washed out and wrong
4. shaking image
5. does not work at all
When the camera does not work at all, I go into the service mode and it is not listed. It's like the computer did not recognize it on boot up.
When the camera is working, I can enter service mode and see it there.
I have a switch installed so I can see the reverse camera all the time. When the camera is not working, the switch will not cause it to work or show up in service mode. When the camera works, the switch functions fine to bring up the image and switch back to GPS screen. I had the issue before I installed the switch.
I am thinking that if the software does not see the camera when booting due to a bad connection or camera, then it will not work until the car is restarted and the camera is found.
Mine seems to be getting worse, I only have the camera about 15% of the time now.
Good info... I am really clueless what to try to do to diagnose it. It just stopped one day switching to camera when put in reverse, and as someone else mentioned it could be a faulty switch but I'm not sure I'm knowledgable enough to fix that!
