BFG TKo2 Size?
Ruiner
Ok lemme try one more time, toyotech boss coilovers, spc upper control, 16inch MK6s.
I was running fjs with 265/70/17s. What size should i be looking at
265/70/16
275/70/16
285/75/16
Dude, you can fit anything up to 35's easily, just depends on how much you want to cut/bend/hammer.
If you have no real need for larger tires, then don't get them.
If its your daily and you like the way it drives now, don't go much bigger.
If its a toy, then **** it, cut away and throw some 37s on.
Suspension lift (without long-traveling) doesn't really let you fit bigger tires, since the tire will still bottom out at the same place.
Getting the right backspacing, alignment, and trimming the pinch weld all make a much larger difference than any suspension lift.
If you decide to stay at the same diameter as 265/70r17, then you want 265/75r16.
On Tire Rack, the A/T tires in 265/75r16 are all load range E.
Lil Chap
