Bilstein 5100's & Cornfed spacers arrived
Pic above also appears to have more rake than the red one on the first page with the same setup.
Pic above also appears to have more rake than the red one one the first page with the same setup.
Thats what i wasnt to sure about either one has more rake than the other. The red one looks perfectly leveled and the gray has a rake. The reason i ask is im going with the same set up and i like how the red looks with the set up, then i see the gray same set up and it has a rake.
Hi all -
I have the set of 5100s with 1" Cornfed rears and was planning to do the 1.75" setting. Now I'm contemplating adding a SSS Slimline front bumper and winch. I'm wondering if this is going to drop my front end too much. Anybody done this? Should I bump up the front setting to 2.5" to account for the bumper weight?
Heres the end result with bilstein 5100s all around [email protected] & 1"cornfeds rears.
Looking good.
I will only say that spacers are a waste of money.
You will eventually get a lift, I guarantee it.
Mine was running a Toytec front spacer kit with the stock suspension before I installed their Ultimate kit about a year later.
I am have the same set up as you, in my garage, ready to install. I was scared into delaying the install by another member claiming I couldnt get alignment into spec without aftermarket UCAs. What issues did you experience? Is it drivible until i can save up for UCAS? I have p285/70r17 Cooper A/T3s. Thanks.
not sure why I never saw your post..... I have OEM UCAs and no issues at all
Looking good.
^^^This. I love my current stance, but would like to UN-preload a bit of the ride. Problem is, I want to stick with stock size tires. Haven't really done a ton of research yet, but at some point, will try to find new springs that yield the same lift as my current ride-height, and allows me to keep/use my current Bilsteins. No rush, just at some point...
Received all the parts.
The cornfed spacers arrived Thursday, took only a week on the nose. Cornfed was great! I emailed them and had a reply in minutes with their PAYPAL links for ordering.
Hey [MENTION=126426]Blue15[/MENTION], where did you order the cornfed spacers from? Are those 1'' spacers? If you don't mind me asking, how much did you pay for them?
I ordered straight from the source, here's the info off my inqury to him:
David Kronberg <[email protected]> 08/03/15 at 12:24 PM
We normally ship spacers the day after ordered via USPS flat rate for 2-3 day delivery.
The prices are $80 + $10 shipping for either of those 2 sizes
For the 3/4" size use this link
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=S6JZND2MKURGW
for the 1" size use this link
https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=5Y9ARALD5S4TG
If you have any further questions feel free to call or text us at (757)303-8286.
Thanks,
David
[email protected]
Hope this helps, Blue15, AKA Jeff
Thanks,
David
[email protected]
Thanks Jeff! :rockon:
blue15 - Good choice - That is the same set up I have, and the ride is so much better than stock. Couldn't tell from your photo the size of the rear cornfed's though?
I have 1" rear cornfed spacers and the front 5100's 1.75". I also have spidertrax spacers. jbstrd - too bad you weren't in Colo, would have enjoyed learning how to DIY as I am looking at small top plate spacers for the front rather than setting them at 2.5" - fun to ponder different configurations, and actually doing that at home would be even better.
No intent to hijack, but since some are asking what this configuration looks like. this is a little uphill and have about 1" rake when on level ground -
Did you replace both front and rear suspension with Bilstein or stock rear suspension+spacer?
thanks - yes toyo at2's - 265/70/17. had some rubbing, but moved the fender liners in and relocated a couple of the fender pins, and took a dremel/sanding bit and took 1/2" or so off the below fender edge on each side - would never know and the edge sanded super quick. I had the spacers put on at the same time so not sure what or how much effect the spacers had, if any.
Had to do the same thing with my (soon to be sold to my son) 2003 4runner on the fender liners. Same size tires, but OME front shocks/coils, rear shocks and toytec rear coil spring - definitely rides stiffer than the 5100's, and I so miss that V8 though...For my driving, no regrets with the 5100's and cornfed set up and so much better than stock - enjoy that set up, especially for the price.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Yes, both front and rear have Bilstein's, spacers in the rear. The fronts set at 1.75", but I did add a wheelers 3/8" top spacer later in front and now have about 2.75" total lift from stock in the front.
Thanks for the info. I have ordered the front set 5100. I think im going to order the rear too and get the 1" rear lift.
