Body Mount Chop
That looks real pretty Booby... I gotta get me one of those shops with all the fun tools... Granted I would probably lose a finger for sure doing this mod...
Does anybody remember the show when American Choppers Paul Jr had to borrow a guys stick welder to fix his trailer? LOL! :toilet3:
Stock suspension or only with a lift?
Nice job on the BMC FactoryRide!Way to DIY!
I cut mine off very similar but didn't weld it back on.(no welder or welding skills,lol) I just left it open,cleaned it up by rounding off the corners,primed and painted. I may have somebody weld them up some day when I go to 35's but work just fine with my 34" tires now.Many on the FJ forum have just cut it and left it open as well as many others cut it off all the way to the rubber mounts and welded a rounded lip on it to look like the other 6. With 35's or bigger you will pretty much have to chop it all the way off to the actual rubber mounts.
Can you fit the 35s with stock suspension?
Sure can! But you will probably rip your fenders, rear quarter panels, fender liners, side molding, and bumper trim to shreds.
If that doesn't bother you than go for it.
frame.png~original
Harper I realize this is an extremely old post but I am curious where you found this picture? I've been looking for this type of information for the 5th Gen and possibly the 4th Gen as well.
Post Note-
Found it in the Collision Repair manual for the 5th gen, unfortunately it does not appear under 4th gen's collision repair manual.
This thread is getting bumped again.
I am going to FINALLY get my body mount chop done next week, thanks to [MENTION=1422]the_josh[/MENTION].
My question is has anyone trimmed the lower fender mount too? See Picture below.
Good deal. I will have them trimmed off.
[MENTION=89562]bimrunner[/MENTION] approximately where did you cut?
Pretty much straight across the pinch weld above the bolt. However, mine was mostly because my sliders run up to the end. This does mean the fender is not tight and can move when pushed on but it doesn't bother me. Just want to warn you if you do the same thing, this is also where the fender is attached to a bracket to make the body panel tight. Mine is not attached back there at all now. I'm ok with that, but just make sure you are ok with that before you cut.
Perfect time for this to get bumped back up. I may be redoing mine this weekend and cutting them way back this time around.
[MENTION=89562]bimrunner[/MENTION] [MENTION=66300]Intruder[/MENTION] [MENTION=78273]Jeremy556[/MENTION]
What sort of trimming did you do on that pinch weld? Any pics?
I didn't trim the pinch weld, just took a BAH to it.
Mine wasn't so much the pinch weld as much as the fender mount. Hammer the pinch weld, don't cut it. It makes sense when you get in there. I don't have any good pics.
Sounds like the BFH is gonna get brought out this weekend. Time to get started to clearance for some bigger tires.
I would this done down the road ... is there any shops here in SoCal that would do this professionally ???
I just showed this thread to my neighbor at work to see if he can chop and weld, he re-inforce frames for those bouncing low riders all day at work. He said he could easily do this, and leave it similar to how Duc left his.
Some of the work he does all day long below:
