bumper build, need input
The bolts are 18mm and the heads are 22mm, nuts are 24mm across the flats. The bolts I am using are from the lower links on an 80 series Land Cruiser. I can buy Toyota bolts cheaper than from a fastner supply. The purist in me makes me use as many Toyota parts as possible.
I can't 100% tell from your pictures but be sure to think about eliminating any path for a stout stick to get past your bumper into the radiator. That's one of the reasons that I went with a plate bumper vs tube since I wheel in Ohio.
Didn't think about a stick in the rad but I am going to build something to protect the plastic tank on the bottom though. I may incorparate some expanded metal for some added protection. As usual I don't have much of a plan so I just make it up as I go and thats one reason I like seeing other peoples ideas.
Would have a picture of yours from the side?
An early picture.
parts036.jpg~original
What do think of the turn signal gaurds? Should I stop with the 1" tubing where it is or would it look better if it ran all the way to the end of the 2" tubing? I still have to add the last piece of 2" tubing.
DSC02874.jpg~original
DSC02875.jpg~original
DSC02876.jpg~original
DSC02877.jpg~original
Well here is the finished product for now. Going to pull it back off and do some touch up and weigh it.
DSC02878.jpg~original
DSC02879.jpg~original
DSC02880.jpg~original
