it says 14.7, and i do NOT have a lead foot. in fact, i drive ECO mode almost 99% of the time (the other 1% is for steep inclines where i can't drive ECO otherwise i'll start rolling backwards lol).
Something is not right here. When I drive in ECO, even just on the edge, I get a minimum of 17MPG on the system. A couple highway trips and it bumps up 18-19+ overall. Majority of my driving is short around town trips.
If you leave your 4R parked and idling that will drop your MPG's also. Do you start it and let it warm up for long periods? Based on what I can see your MPG's match up to how fast you are going through fuel, doubt you have a leak.
I personally have a heavy foot, at half tank now, and i'm at 16.5. I can easily back off and get it above 17-18. I have just under 2k on it now, picked it up in November and the milage was just the same when new, and getting better.
no sir! i do not leave it idling for more than 4-5 minutes. at first, i left it idling for 10 min and did this on 3-4 occasions. but since i started worrying about this gas issue, i've not been idling for more than 4-5 min at a time, and even then i've only done it this for 4 or 5 occasions.
i reset the MPG reading an hour ago, so i guess i'll have to wait and see how it goes in the next few days. after reseting it's now at 10.6 and yes I was driving ECO the entire time, not using AC or other accessories.
I would check the air filter/intake. Using that much fuel doesn't sound right.
so my empty fuel light came on today, and at 297 miles i refueled a total of 20.121 gallons. assuming that the dealership gave me a FULL tank at delivery, that means my mileage should be 297/20.12 = 14.7mpg ... pretty crappy for someone who drives ECO almost ALL the time.
i took my truck to the service dept and they were not very helpful as to what the problem could be. didn't say anything about it being normal for the truck to use more fuel when brand new and did not offer any possible explanations (EVEN after being prompted to provide them) as to why my mileage may be suffering (thanks a lot First Team Toyota service dept!)...
they did mention that i should keep a ledger of my fueling, mileage at such fueling, avg mpg, etc... which i am already doing and did not need them to tell me this common sense obviousness...
when i refueled today, i also reset my MPG counter for the SECOND time, and this time, i'm actually getting decent readings. i am currently sitting at 18.5mpg and earlier today was at 19.7 or something like that...
i'll update here the next time I refuel with the results...
i realize you're already keeping a log of your mileage... just wanted to say that if you have an iphone there's a smart little app called "gas cubby" that does a good job tracking that stuff. also tracks maintenance, etc.so my empty fuel light came on today, and at 297 miles i refueled a total of 20.121 gallons. assuming that the dealership gave me a FULL tank at delivery, that means my mileage should be 297/20.12 = 14.7mpg ... pretty crappy for someone who drives ECO almost ALL the time...
My GTI reads "full" with nearly 3 gallons less than full. I'm going to guess that you probably got a certain amount to where the tank looked full. My first tank in my GTI was also at 26mpg where I've averaged over 30mpg the other 54000 miles I've driven it. Basically, don't put too much stock in the first tank. If I were the service department, I'd want more data showing poor fuel economy before I dove into a deep investigation. Give it a couple tanks and see how things are going after that.
Things that kill your mileage:
- several hundred pounds of extra weight in the vehicle (especially in urban driving)
- lots of stops on your normal route. Remember, you are turning all this fuel into energy just to turn it back into heat when you have to slow down or stop. Even "eco" mode isn't going to help too much here.
- look ahead and anticipate traffic. If you see a light that is green 1/4th of a mile away, it will probably be red when you get there. Just coast to the light instead of trying to make it.
- drive smooth and predictable. The transmission is trying to anticipate what you're going to do next. It is a computer that can only do so much w/ the inputs it is given.
Is your S.O. driving any? My GTI fuel economy drops like a rock when my wife gets in the driver seat.
Good luck.
good luck and hope your MPGs rise to meet your expectations.
