CutthroatSlam
Senior Member
Since changing the spark plugs last week, we are periodically getting Code P2443 OBD-II: Secondary Air Injection System Switching Valve (AISSV) Stuck Closed. I did have to redo a butt splice to a previous repair to the plug that goes onto the sensor next to the AISSV on the drivers side, but I’ve checked that several time and it is solidly connected as are the other 2 wires to that plug. When I pulled the AISSV to replace the spark plugs, I unplugged the harness and laid it up ontop of the intake.
This code only appears infrequently on start up. Per the description of its function, it pumps external air into the exhaust on cold starts. So I’ve checked wiring. Will check vacuum hose. Not sure how to check the rest.
P2443 OBD-II: Secondary Air Injection System Switching Valve Stuck Closed
Get diagnosis and repair information for trouble code P2443
OBD II Fault Code
OBD II P2443
OBD-II Code Powertrain Control Module (PCM) failure is defined as a Secondary Air Injection System Switching Valve Stuck Closed
The Secondary Air Injection System pumps outside fresh air into the Exhaust System during cold engine start up. This additional air helps burn up the highly rich exhaust emissions that are produced when the engine is warming up. The Secondary Air System typically has an Air Pump and some tubes or plumbing to route the air. The system also has a solenoid and Check Valve(s) to control the airflow. When the engine control module (PCM) detects a faulty with the Secondary Air Injection System, it will set code P2443.
Common Problems That Trigger the P2443 Code
Clogged or disconnected vacuum hose
Secondary air pump control valve failure
Secondary air pump failure
Wiring issue
OBD II Fault Code
OBD II P2443
Wiring issue
