Direct Replacement LED Fog Light Assemblies for 2014 & Other 5th Gens
I will be attempting to do the install tomorrow.
Does anyone know if there another way to install without removing the entire front bumper? I know the OP says you have to remove the front bumper for the 14 limited. thx.
^ TY sir! I feel better that no bumper removal is required but
I'm a lil embarrass to overlooked that and didn't pay attention. lol.
^Is the cover you describe on the passenger side? Need to pop if off. There are locking tabs in each side. PITA to remove but doable. The good news is that the driver side don't have one.
On the limited, the cover is part of the bumper. I follow barry's removal of the fender liner and reached in to the 3 clips and 1 screws each side. Once successful you can pop the bumper/fog light cover from the outside.
Thanks for posting a picture, unlike someone else whom I won't mention............................................... [MENTION=103267]Saker[/MENTION] :hiding:
:deadhorse: :bolt:
Ha-ha-ha, just kidding
Also, if you are planning to reuse the oem bracket, you would need to drill the 2 pivot holes 15/32"(morimoto) vs the 7/16" (oem)..very minor. Using the oem bracket will allow you to adjust with a long screwdriver from the front of the bumper.
Just installed the Morimotos and they are awesome. Installed some LED turns to. My front end is finally the way I want it as far as lights go. Install was so easy a caveman could do it.
Folks -
I am considering a set of these Morimoto LED fogs. Several posts have referenced a gap that is "acceptable". I have searched, but have not found any close up after install pics. Would someone mind posting a few pictures of the LED fogs installed, so I can see what the gap looks like in comparison to the stock fog lights? Thanks for any assistance.
Lexus has a Few models with LED fog lights, ISF, ES350, LX570.
The part numbers are:
81210-48050 - RH LED Fog
81220-48050 - LH LED Fog
For my 11 SR5 they were plug and play (zero modifications, zero cutting, zero rewiring) aside from the pita of removing old ones and installing new ones.
Mind asking the price? and did you have to reaim after swapping?
Thanks HarryHiram- Not the same fit as factory, but looks okay.
Most appreciated.
No problem Sawgie :bolt:
But I disagree, what the picture doesn't show is that the fog light lens actually is almost touch chrome trim, there are no gaps. They look and fit exactly like factory...........at least on 2012, can't speak about 14's, I defer to [MENTION=103267]Saker[/MENTION]
BarryHiram-
Thanks for the clarification. I am all over them now. If you hadn't taken the time to square me away on the details of the fit, I would have skipped the mod thinking there was too much gap-osis for me. Now it is go time....Appreciate it.
Anyone run into issues while installing as far as not working??
I did my driver side first, installed nicely even though the holes dont line up and you got to force #2 bolt in but very nice, power it up to make sure it works and very nice, nice color and brighter.
Go to install passenger one (yes that extra cover is PITA but once you get it its easy) anyway hook it up and go to power it up and NOTHING, even the driver side not working. Any help?
Summery:
Fuse ok
New fog(D)+ OEM fog(P) work at first
When New(P) installed neither work
Went back and hooked up OEM(P) and that worked but new(D) doesn't work anymore
What am i missing?
Did you check polarity on both LED units?
On my 2014 TEP, White(+), White/Black Stripe (-)
that is how i wired mine, i did both sides the same and the driver originally worked until i did passenger one now neither work, but stock ones work
